Question about Sony Playstation 3 (PS3) Console
Hdmi problem i'm having problems connecting my ps3 to the tv through the hdmi cable
  • 1 more comment
  • Anonymous May 02, 2008
    my ps3 hdmi aint workin on my samsung tv the tv just says that it cant use this mode, when the hdmi is working.
  • marra73 Oct 30, 2008
    I have a Samsung 650 52Inch and it keeps saying mode not supported when I try and connect the PS3 via the HDMI lead. Tv costs over $2000 and I get this problem. Should just be plug and play. Sony advertised their PS3 as HD and I get this... can somebody please help!!!?
  • Anonymous Mar 15, 2009
    I'm on a samsung tv as well, and I am getting "Not Supported Mode" on my tv screen as well. Haven't had this problem before, so I'm not sure what to do.
  • 27 Answers
From the Ps3 connect the hdmi and turn it on...
from the tv choose hdmi...
if nothin shows up shut down the ps3 and press on the console to start it but keep your finger ther for 5 sec to reset the video output...
you should get a message on the screen and then go to the Display setting and choose Hdmi and the resolution you want,preobably 720p
Posted on Mar 15, 2009
That old trick of "resetting" the PS3 by holding down the on/off button may work for a few consoles but I know for a fact it doesn't cure a large amount of peoples problems with this HDMI issue.
The crazy thing is most ps3's have worked fine for months/years even on HD tv's before and then one day it just goes down - mode not supported etc. Thats what happened to me and many others that I have spoken to about it.
My ultimate solution was to call Sony Playstation helpline direct and explain the problem... they were extremely helpful and knew the porblem. My PS3 was out of its guarantee too!!! Yet they still offered to exchange my "broken" PS3 for a refitted one. At no cost to me they replaced it and this one works fine. If nothing else works, you've done the reset thing, you've tried 2 or 3 different HD leads... then call Sony up and get them to replace your PS3...
HMDI 1 and 3 do not work (why) ?
Since you did not mention HDMI 2, I assume you have that connected to something else, and that is working properly. The following procedure is based on that assumption.
First, turn off everything connected to the set, and the TV itself. Disconnect the HDMI cable from whatever is going to HDMI 2 (leave the TV end alone for now) and connect it to the PS3. If the PS3 shows up on the TV, the problem is most likely a bad cable. To verify, turn off the PS3 and the TV, then move the known good HDMI cable to either HDMI 1 or 3. If the PS3 works on those also, the HDMI cable you had originally connected to the PS3 is defective. I know there are some bad ones out there; there is at least one lot with a right-angle connector on one end and a straight connector on the other that has a very high failure rate.
If the PS3 does not work with a known good cable to HDMI 2, then the PS3 has a problem. Try using a component (RGB) or composite (yellow end) connection to narrow down what the issue is.
If HDMI 1 and 3 do not work with a known good cable or any input source (DVR or cable box), then the HDMI switching circuit inside the TV is defective. Since the set is "new" that would be a warranty issue.
Jan 03, 2015 | Westinghouse 55" Class - LED - 1080p -...
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
PS3 no longer communicating with TV
The problem is with your PS3 itself.
If it's still under warranty, take it back.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Sony Playstation 3 (PS3) Console Logo
232 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
