Question about Recoton Advent Advent Q2035A 20" TV
Digital tuner I am trying to find out if this model has a digital tuner but none of my manuals or paperwork say...
No it does not have a digital tuner. It has a NTSC tuner. Sorry for the bad news.
Posted on Feb 19, 2008
I have a 32" Advent TV, I can view DVD but no regular cable stations. Any suggestions?
Posted on Feb 05, 2008
I have a DP50842 Sanyo LCD tv. does it have a digital tuner built in? if so how do i use it?
Here are the specs, it has a digital tuner:
http://us.sanyo.com/LCD-Televisions/50-Class-49-5-Diagonal-LCD-1080p-60Hz-HDTV
If you do not have the owner manual google the model number with "manual" to try to find it.
Nov 04, 2012 | Televison & Video
Does my Curtis Mathes Tronics model 19001 have a digital tuner?
No,all small tvs CRT tubes analoge tvs design under 35" none of the tvs have a digital tuner inside of it tv Tuner signal board.Must get a signal through a Digital Converter box to recieve a free on AIR broadcating channels from a Digital broadcasting signal.Tvs that are analoge CRT tubes design that have a Digital Tuner design inside of it are only some DLP tvs analoge CRT tube design 40" and above have it only.
Aug 09, 2011 | Curtis-Mathis CM19011 TV
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 | LG LRY-517
Digital tuner not picking up signal
If your trying to get digital stations over the air with a standard ntsc tuner it will never happen. The set must be equipped with a ATSC tuner, that's the one that will receive digital signal over the air. (not cable) If you have the tuner in that model then the signal must be very good or it will display "no signal". Give me a model # quick and I will do the homework for you now.
Apr 15, 2009 | Televison & Video
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Freeview not working
The tuner may be defective, or the reception is too poor for the set. A service tech who is qualified to work on your model of set can go out to your place with some field test equipment and verify the performance of the set for you.
The tuner and or IF modules, or main video processor module may be at fault. These modules can be replaced if necessary.
Before having a service call, read the instruction manual to make sure that all the user settings are correct to recieve programs from the tuner section. You can call the Panasonic tech support for assistance.
Jerry G.
Dec 18, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
We have a TV in our 2007 5th Wheel RV unit and we need to know if it's a digital TV. We did not receive any paperwork for the television. The model number is TVM1916F or possibly TVM1916E. Could you let...
This unit has a 181 channel tuner and while I can't find anything that states it has a digital tuner, it sounds like it does. The easiest way to find out is to check the setup menu. If it has a digital tuner, it should give you the option to autoprogram the digital channels.
Hope this helps,
Dan
Sep 04, 2008 | Televison & Video
RCA Universal Remote RCR4258
ive got the same problem.
Did you ever solve it
Sep 04, 2008 | RCA Universal Remote Control
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
manual
<A href="http://www.uwsp.edu/cps/facilities/classroom/manuals/VCR/PVD4752.PDF">http://www.uwsp.edu/cps/facilities/classroom/
manuals/VCR/PVD4752.PDF</a>
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
Recoton Advent Advent Q2035A 20" TV Logo
143 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
