Blinking standby light
Standby light blinking and unable to power on. Did not attach a computer to it.
  • 3 more comments
  • Anonymous Feb 21, 2008
    Mine is a Samung LCD But the same problem won't turn on just blinking yellow light model LTM1555B model code LTM1555BX/XAA. Turn it off and on, plug it into other outlets with different cable jacks but problem still continues also plug it into my computer and the problems is still there its as if its on stand by and won't come out.
  • Anonymous Sep 02, 2008
    standby light blinks 6 times then repeats wont power up
  • antonela2000 Dec 28, 2008
    Blinking St-By light but TV can not to switch ON.
    This is a Third time is happening.Previously after few HRS.was switched on
    but now more than 24hrs blinking st.by light without switching on.
    From inside is possiblle to hear some noise as a continious HDD. reading.
    Please if you can instruct what to do.
  • Xaphos Jan 23, 2009
    Mine is a LN40A500T purchased on Black Friday from Wal-Mart. Worked great for almost 2 months, but now wont turn on. The stand-by light blinks twice like Morse Code, but I don't know what the code means.
  • efrainrivera Mar 25, 2009
    Blinking Standby light,blink's 5 times,when i press the power standby & on light turn on.The screem show for second.Then it turn off,The standby light stay blinking.
  • 42 Answers
Please provide a model# and brand name & chassis if possible.
Posted on Jan 14, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Unplug the set for 15 minutes ...... plug it back in and try it....
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Standby light keeps blinking but no picture
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
KDF-70XBR950 70 in. Rear Projection HDTV Television My TV took a power surge and I?m getting the 3 blinking lights, I read online that it?s probably my g3 board. I check the lamp and the cover but...
3 times red standby blinking light indicates Lamp Cover is not attached securely or Lamp has not been fixed properly inside tv. Make sure lamp and lamp cover are securely attached in tv.
I do not think G3 board is bad because 3 times blinking error is related with lamp cover that engages micro switch inside tv.
Let me know your findings to provide you more helpful info.
You can download service manual from This Site for little fee.
Thanks.
Jan 14, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Kdl-52xbr4 5 blinking standby lights
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
Green blinking light
Oct 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
4 fast blinking lights
Oct 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
466 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
