Not working Set Top Box
I have tried to connect to Set Top Box to the TV as per the User manual and it still does not work. What am I doing wrong.
Dear friend u cheack that u proparly inseret card or not, if no then correctly insert it by seeing upper and lower side. if yes then cheack pin out and in connection.
Posted on Jan 15, 2008
I have a JVC HD-70FH97 hooked to my digital box, via HDMI cable, and connected to the TV HDMI input 1. I cant get my surround system to work - any ideas what im doing wrong?
Check your HDMI audio settings. It may be trying to send a signal that is incorrect. How is the wiring setup? cable box to stereo, then to Tv?
Sep 21, 2016 | JVC HD-70FH97 70 in. HDTV Television
AV4 input
To get your over the air signals, you would of course hook up the outside antenna cable to the back of the TV set, as per the owners manual. Then go to channel search in the set up menu as per the owners manual, then do a guide plus set up and follow the directions word for word in the owners manual. It is just way to long to explain here. In case you do not have the owners manual, you can get one from here http://www.p4c.philips.com/na4/3/34pw981599/34pw981599_dfu_aen.pdf Good Luck
Aug 26, 2007 | Philips 34PW9815 34" TV
I need to find the user manuel for my audiosonic hdtd601 DVD set top box my remote control for the device has stopped working and I'm trying to connect it to my Sony Bravia TV REMOTE RM-GD003 HELPME
Hi Dennis, The sony bravo remote will only work with that television, You'll need either the same remote that stopped for your Audiosonic set top box or a universal remote........CHEERS..
Apr 07, 2016 | Sony Televison & Video
With set up box audio in to tv causes high pitch sound
I am assuming this should read 'Set top box'. What kind of cable are you using?
Usually the set top box connects via a SCART lead but yours may be HDMI if it is a very new set top box.
If you are using RCA plugs, you may have cross connected the wrong cables. The RCA cables should be colour-coded. RED and WHITE are for audio, Yellow is for video.
Best advice is to switch it all off, remove all the cables you attached, and start again. The instruction manual/user guide usually has an illustration to help you identify what your set up looks like - there are usually several examples.
If the cables you need did not come with the set top box, you will need to purchase them.
When you are connecting audio leads, you should use the 'audio out' on the set top box and the 'audio in' on your TV set.
It would help to know the EXACT model number of LG screen you have and the make and EXACT model number of the set top box.
Good luck.
Mar 07, 2015 | LG 42LC2D 42 in. LCD HDTV
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
Im having trouble hooking up my desktop computer up to my Akai LCT3285TA tv? what am i doing wrong? I have both VGA hookups connected and screen says not supported?
The screen indicates 'not support' because the resolution you are try to feed the TV exceed the maximum it can display, you need to set your computer video out put resolution the TV native resolution, which you need to find out by download the user manual here: http://www.retrevo.com/support/Akai-LCT3285TA-TVs-manual/id/741bh147/t/2/
Dec 15, 2009 | Akai LCT3285TA 32 in. LCD Television
Sound from my tv card, skydude doesnt work on my hp laptop, vista home premium
You haven't mention about the connections you have with the SKYDUDE TV box. TV boxes usually have AV (audio and video) connections i.e., two seperate connections for audio and video signals. If you are using a set top box to connect to the tv box you can connect the "video out" of the set top box to the "video in" of the tv box using a cable. and "audio out" of the set top box to the "audio in" of the TV box using another cable. Some TV boxes don't have the "audio in" option. In that case you have to connect the "audio out" from the set top box directly to the "audio in" of the computer. This pin you can find just near the "speaker" and "mic" connections.
If you have an S-Video pin in your TV box, you can use an adopter wire to connect two "audio in" and one "video in" connections to the same pin. And you have to select S-Video option in the software installed.
If you have "RF in" option in your TV box, you can use use AV to RF converter to connect your set top box to the TV box.
Thank you,
Apr 25, 2009 | Computers & Internet
Base rw Model dw-2200 dvd player?
ok first connect the red/white/yellow output of the dvd to the top box red/white/yellow input. Get the extra a/v cable then connect to the red/white/yellow output of the top box to red/white/yellow of the tv a/v video input A/V1 or A/V2 and last connect the RF aerial to the top box antenna in.
May 13, 2008 | Televison & Video
Can only record in black & white?
try changing your Display/ TV Connection setting under the setting menu - it may need to be set to "composite" (not RGB) if connected as displayed in the instruction manual - worked for me anyway (hope it does you).
Jan 21, 2008 | Archos 605 WiFi Digital Media Player
 Grubhead
Grubhead
