Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
WHITE LINES OVER PICTURE
I HAVE A C 8080, WHEN YOU FOCUS ON THE SUBJECT THE PICTURE IS FINE AND THEN WHEN YOU TAKE THE PICTURE IT COMES UP WITH WHITE LINES ALL OVER IT
  • 593 Answers
Shoot in RAW, or in black and white, see if it helps. If you shoot in B/W, you can post process the color back in wiht photoshop, itsw a hassle but a workaround for a bad ccd or compression problem.
Posted on Feb 19, 2008
    Problem Solver:
  • 6 Answers
Hi BOONA,
If live video is ok but captured image is displaying "drop out" I would firstly try switching memory cards as it sounds like you may have a memory location issue. Try a simple test of switching over to your XD card and see if the problem still exists. If this works OK you were probably writing to the CF card, but as flash memory has a finite write cycle life (500 to 1000 overwrites) the CF card may have become faulty.
If you still have the same problem on XD as well, then try using the "pixel mapping" feature in the camera menu to see if this re-addresses a CCD image correction problem.
If still faulty then it is most likely the graphics processor circuity in the camera and it will need to go in for service.
Good luck...hope it goes well for you.
Mark
New Zealand
Posted on Jan 14, 2008
My camera will not stay in focus
Not sure what could cause the white lines. Are you sure you did put the camera in automatic mode? if it is in any other position, it could be you force it to overexpose. In the manual are several causes, why the camera can have trouble focusing. too little contrast in the subject, is only one of the reasons.
Please check the manual for the settings of the camera.
Jan 21, 2014 | Olympus Stylus 790SW Digital Camera
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
When using my d80 (no matter what lens is on it) it just keeps trying to focus and will not take the picture. It was fine on Sun and then Tue wham!! I can not think of doing anything to it and no one has...
Be sure the lens is firmly switched to M/A. For some reason the camera is not acquiring a subject to focus on. Have you tried a simple subject with lots of contrast, like a black something against a white background. Cameras have a tough time whenever there is too little contrast or nothing specific to focus on.
Sep 23, 2009 | Nikon D80 Digital Camera with 18-135mm...
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
C-8080 out of focus at all times
Here is the link to the manual; http://www.olympusamerica.com/files/C8080WZBasicManual.pdf Check page 31 - "focus lock" - it sounds like that could be your problem. Hope this helps, please post again if you need more info :)
Nov 13, 2006 | Olympus Camedia C-8080 Wide Zoom Digital...
AF Illuminator
The AF illuminator allows the auto focus system to focus on dark subjects. When the shutter button is pressed half way, the AF illuminator will light up the subject. The default setting is “ON”.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
55 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
