Question about EliteGroup K7S5A Pro Motherboard
EliteGroup K7S5A (does not say pro on the board)
What max CPU can I fit in this board.(No manual for it)And what video card ??
I am trying to use this PC that was given me and trying to upgrade for max use.
It does work OK at present but would like to upgrade to get the most out of it for a teenage lad to use.
Paul C
  • Anonymous Aug 13, 2008
    I don't have driver
  • Anonymous Aug 14, 2008
    I HAVE LOST THE DRIVER
    Sergeant:
    Champion:
  • 333 Answers
This m/b has a socket 1 which supports amd k7 processors
Athlon 650 MHz - 1.4 Ghz, FSB 200 Mhz,266 Mhz
Duron 550 - 950 Mhz FSB 200 Mhz
Memory SDRAM or DDR
I have manual for K7S5A if you want any more info. No mention of 'pro'
Posted on Feb 03, 2008
  • 4 Answers
According to their website, the board can take:
AMD Athlon XP (Throughbred up to XP2600+)
AMD Athlon (including Thunderbird)
AMD Duron (including Morgan)
You can then overclock the processor with a BIOS upgrade available at http://www.ocworkbench.com/2002/ecs/k7s5abios/cheepobios.htm.
It has one 4X AGP slot so it can take any AGP video card, assuming the card is backwards compatible (8x -> 4x).
Posted on Jan 13, 2008
6ya staff
SOURCE:
I have an elitegroup k7s5a pro. every time i turn it on all i get is a black screen.i have replaced the video card more than once an with one that i know is good so i dont think it is that ,can u give me...
with the error of video card, you can hear the warning beep of mother board.usually one long two short. if you don't hear anything .check memory card or cpu is installed firmly.
Oct 28, 2010 | EliteGroup K7S5A Pro Motherboard
Find the correct connections on motherboard for usb ports
frist you have some port of usb on front pannel of cpu . connect the wire of usb . u can plug the usb card from on board pci slot then you need to enable your usb in bios
Apr 10, 2010 | EliteGroup K7S5A Pro Motherboard
Would A 1GB PC3200 run in the K7s5a alone.
According to the specs the max amount of ram is 1 GB and max speed is pc2100 so a pc3200 would not run on it unless the board was able to clock the speed down of that single stick of ram.
I was not able to find the max amount of ram per slot on a quick search but most likely it would be 512 mb per slot for a max of 1 GB between the two DDR slots.
at Newegg you can find DDR 266 1 GB kits (2 x 512mb) which would get you the 1 GB of ram.
Jan 08, 2010 | EliteGroup K7S5A Pro Motherboard
Elite Group K7S5A Boot Problem
Try this... Remove all cards, hard drive(s) and cables, such as cdrom and floppy, except the video connection so that you can see what is going on. Go to the bios setup. Set all of the bios settings to default as you exit to reboot. Then try again. By setting the bios, that should take care of it. Then replace the other items, cards one by one and watch the reactions.
Hope it works.
Nov 06, 2009 | EliteGroup K7S5A Pro Motherboard
I am working on my friends k7s5a Pro Mobo...
If you wish, tell us the socket number and we can then look up your board specifications. My guess is that the board runs pc2700 chips as the max speed possible.pc 3200 is faster(400MHZ)    than pc2700(333MHZ).
Mar 19, 2009 | EliteGroup K7S5A Pro Motherboard
Need drivers
To download drivers for the EliteGroup 7S5A Pro , click on the link below.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=269&DetailName=New&DetailDesc=K7S5A%20Pro%20%20(V5.0)&CategoryID=1&MenuID=82&LanID=0
Most common issue's for not being able to boot PC system.
1. Swap power cord/replace. Check video connection cable,
Check monitor power cable. (Check wall outlet is good).
2. Reset cmos/bios. (Need to use manual for board to reset)
3. (No display on monitor, can hear fan's running & LED's on case light/flash). Remove & re-seat video card, same for memory. (While in PC check all power connections & data cables to devices.
4. Fans not running & no LEDs do not light/flash. Power supply may be bad.
Luck!
Mike
May 01, 2008 | EliteGroup K7S5A Pro Motherboard
Elitegroup K7S5A board No Docunentation
The following link is the download page for Elitegroup Motherboards, just choose your motherboard in the side, i think it under Socket 462!!! http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=9 hope this helps regards, babb
May 10, 2007 | EliteGroup K7S5A Pro Motherboard
EliteGroup K7S5A Pro Motherboard Logo
364 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
