Question about ViewSonic VA903B Monitor
Blury picture my screen is all blury in 70 and 72 hz mode,when i change in 60 hz mode its all ok. what is happening?? i try manually adjust but nothing helps i have this monitor 3 months and hi work fine until yesterday. what should i do? pls help me
I had the same problem.
Just fixed it.
Check the cable on the back of the monitor.
Make sure it is plugged in properly.
Wiggle it a bit, and the ghosting dissappears.
Don't tighten the cable to the PC too much.
Posted on Feb 14, 2008
How can I adjust the height of the HP LP2465 24" LCD Monitor?
May 21, 2014 | HP LP2465 24" LCD Monitor
I am getting a message traveling across my screen that says, "Input Signal Out of Range." Then, after about 1 minute I get a "going to Sleep" message, and the screen goes into sleep mode. I keep having to...
that message means, you have the unstated PC, set to a super high resolution, that is totally ******* on this old screen,
buy a newer screen,
or change the resolution.
no PC stated , at all. model , is it HP?
no OS stated, if XP hit F8 and run safe mode and lower the resolution to 1024x768.
only these work,,never higher.
1024 x 768 / 60 Hz
1024 x 768 / 70 Hz
1024 x 768 / 75 Hz
800 x 600 / 60 Hz
800 x 600 / 72 Hz
800 x 600 / 75 Hz
640 x 480 / 60 Hz
640 x 480 / 72 Hz
640 x 480 / 75 Hz
832 x 624 / 75 Hz
720 x 400 / 70 Hz
Aug 28, 2017 | Compaq FP 5017 15" Flat Panel LCD Monitor
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors:
Mar 30, 2010 | Computers & Internet
I'm changing out my monitor from a large CTR monitor to the LG monitor I plugged the monitor into my computer that is running xp I get a screen that says it is not in range what do I do to fix the problem...
restart your computer hit ALT F5 run safe mode setting graphics rasulation adjust monitor frequency only 60 Hz and again restart run normal mode then its OK. if are not OK again install windows this monitor.
Nov 23, 2009 | LG L1520B 15" LCD Monitor
I have a Westinghouse LCM-19v5 monitor. When I start the computer, after the startup screens, the monitor goes black and I get a red bar with the message "Out of Range." I am in safe mode right now, the...
in the safe mode you have to change the resoulution and the frequency to 60 hz you can get it by fright click on the screen and then choose properties and then choose settings and adjust the resolution to 1280 to 800 and then choose advanced then choose monitor then choose the frecuancy to 60 hz ok and apply ok and insa every thing will be ok conntact me for more if you still haveing the same problem
Nov 14, 2009 | Westinghouse LCM-19v5 Monitor
I can´t play xbox 360. The xbox says change to 60 hz mode, and when i do, the picture gets messed up and won´t support 60 hz. 50 hz works fine though, but I can only use my xbox as a DVD...
is this on hd mode?, if so it needs to be on 1080i as 1080p will not work that high up. Also if you are not using the component lead then you should the picture is fantastic.
Jul 09, 2009 | Videoseven LTV30C 29.6 in. LCD Television
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
No clear picture just wavy lines and error message
The spec sheet I found says your monitor should be able to display 1280 x 1024, 720 x 350, 720 x 400 and four other resolutions in the 640 x .... range which are pretty useless. Try setting ti to 1280 x 1024 at 16 million colors @ 60 Hz and let us know what happens.
Nov 26, 2007 | IBM 9516 Monitor
Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Sep 24, 2007 | ViewSonic VA703B LCD Monitor
ViewSonic VA903B Monitor Logo
148 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
