Amber system light is on
We have a mitsubishi digital tv model wd-52631.
my wife turned on the tv within 10 minutes a message on the screen showed the tv was shutting down.
now the amber system light on the front panel is on and the tv will not turn on.
  • 1 more comment
  • Anonymous Jun 02, 2008
    i have this problem, too. Mitsubishi sucks.
  • Anonymous Sep 02, 2008
    This problem occurs way too frequently. The tv is not closed in and should have plenty of air flow.``What is the problem?
  • c1979h May 11, 2009
    I have a WD-Y65, nohing is blocking the airflow, I believe the fans has stopped blowing
Had the same issue, we even had a personal fan blowing air behind the tv and the message always comes up right when we turn on the set and the tv turns itself off after about 30 seconds. did some research and it turns out there is no air flow problem just a faulty temperature sensor inside the set. Mitzubishi knew about this since 2006 but didn't really aknowlege it until more recently, they admitted it was a problem with the sensor and are now extending everyone's warenty by 2 extra years so if you got it with a year warenty and you bought it less than 3 years ago, call mitzubishi's 800 number and tell them the temperature sensor needs to be replaced, they'll get you in touch with the nearest service center and a service man will come out and replace the sensor at no charge for parts or labor. hope this helps
Posted on Sep 11, 2009
  • 42 Answers
The air flow is being blocked. Be sure that the sides of the set are not restricting air flow to the tv. If the unite is in a tight entertainment center it cannot get air flow.
Billy
Posted on Jan 14, 2008
    President:
  • 3,130 Answers
Replace the bulb in the set . It should explain how to do this in the owners manual. Good Luck
  • siotha Sep 05, 2010
    did that. didn't work. still having this problem. it happens every summer, and the coldest part of the winter
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Outer screen scratch
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
TV has no picture, shut off in the middle of a show.
Greetings!
There's a part inside of your tv that over heat, when a minute comes it stop because of the heat. Better check with a tv technician or repair man before the damage became worse.
Thanks.
Nov 13, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Wd 57731
Thats a lamp abnormality, sound like the two 3300uf caps on the PWB PCB need replacing
Jun 29, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Televison & Video Logo
500 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
