The F3 error code is usually for a bad oven temp sensor. You will need to disconnect the wiring harness for the temp sensor. Then take a reading with a ohm meter at both connections at sensor. You should get aroun 1100 ohms at room tempature. If the sensor is open(no complete signal) then it is bad and replace it. If the sensor tests good then it is a possible bad control board for range.
