Question about EliteGroup 945G-M3 Motherboard
ECS 945G-M3 PC build problems
My son is building a PC using this motherboard, Celeron D (2 GHz)processor, 2 sticks of Kingston 667 1Gb RAM, PSU is a Colors 450W unit . Its all together and connected (correctly as far as I can tell). He now wants to install the os but on power up, while the motherboard, front panel and fans all fire up fine there is a brief blink of LEDs on the monitor and keyboard which then go back to standby. It did take a few goes to get it to fire up as far as it has got so far and I do. The BIOS WP jumper is Open. Another oddity is that when powered up it causes interference on AM radio reception......
  • 1 more comment
  • married5658 Jun 29, 2008
    My problem is similar, my machine got wet, I dried, wiped,, blew,,, unplugged some plugs on the board to make sure they were dry. I'm not sure if I have the pwr swicth and pwr ind led plugs back in the right place, But it just gets a blink on the keyboard,, nuthin else.
  • Modders Mar 04, 2009
    Apparently this a common problem with these motherboards - if you catch it in time you can get a warranty replacement for a board with this problem. We've put a new one in now and it works just fine.
  • Richard Ray May 11, 2010
    have you got the cpu 4 pin connector plugged in as the cpu needs seperate power
I am having similar problem, I bought new ECS 945GCT-M/1333 motherboard with Intel E6550 processor and VGA connector connected to Monitor. I am trying to turn it on with minimal configuratio, CPU, 2GB Corsair 6400 DDR2 memory, to see if comes up with BIOS. When I turn power ON, CPU fan starts, but nothing else, no beeps on speaker, no BIOS display on monitor. I tried two different motherboards, two processors, and two memory sets, same thing happens, any idea why? It is connected to ATX power supply 24 pin connector, no aux12V connector connected.
Posted on Feb 03, 2008
  • 44 Answers
Reading your manual:
On page 23, In bios, select 'advanced' menu item from top, then second option below should be 'OnBoard VGA Share Memory' - set to 64MB.
Posted on Jan 14, 2008
Ecs 945g m3 motherboard manual
IF the computer starts up, runs smoothly for up to 5 minutes, then shuts down, it might be a heat problem. Firstly disconnect all fans, then using a blower, blow out all the dust inside the computer. switch on and test. Reply if problem is solved or not.
Dec 28, 2013 | ECS 945G-M3 (V3.0) Motherboard
Manual for Powerspec Computer V100
Hi. Your mainboard is an ECS 945G-M3
Here is the manual for the mainboard:
And the mainboard manufacturer website:
If you want info about the Tower in general hare is a link to the V100 page on the Powerspec website that will tell you about the components they used to build the system:
Hope this helps... Dale
Apr 22, 2011 | Computers & Internet
I have motherboard i845G with intel chipset i845GL , processor is Intel celeron@1800 MHZ. Ram is DDR SD256 MB Ram. Can I upgrade my RAM to DDR 2 1GB RAM.
No each type of ram is different, it wouldn't even fit in the slots, nevermind use it. To upgrade to a different type of ram you'll need to get a new motherboard. Unfortunately there aren't many motherboards that'll take your processor any more, unless maybe if you try to get a second hand one.
Here's a link to one, there may be a few more available elsewhere though
If I were you I'd think about building/buying one with a newer processor. If you decided to build one yourself, then you could get a new motherboard, ddr2 ram and a new cpu for about £150 and use the other components from your present system ie. case, dvd drives, hard drives, although you may have to get a new power supply if your current one can't supply enough power, that would add another £50 for a decent reliable one, go for a decent make like antec or ocz
Obviously I'm in England so it may be cheaper or more expensive depending on where you live. The links below are for an example of what you could get if you decided to build a new one. - Antec 400w psu £47.43 may not be needed though - E5500 2.8Ghz dual core processor £49.40 -Asus P5KPL-AM EPU motherboard £31.98 - Crucial 4gb ddr2 800mhz ram £58.75
Jan 21, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Just a follow question regarding ecs 945g-m3 motherboard.. is this compatible for core 2 duo processor with 45nm technology like Intel E7500 (2.93G) 3mb 1066fsb C2D.
According to the ECS website, it should support the 1066 FSB C2D, however it mentioned it's on the 65nm technology. Latest processor support shows for the E6420. So, I doubt it would take the 7500...
Oct 03, 2010 | Computers & Internet
What motherboad is installed in an Emachine W3507 Desktop PC
The motherboard is a Socket 775 board originally manufactured by Elite Group (better known as ECS). When placed into this E-Machine, very few changes were actually made to the retail version of the 945G-M3 motherboard. This motherboard was built with upgrading in mind. It supports almost every Celeron D, Pentium 4 and Pentium D processor on the market.
Nov 05, 2009 | eMachines W3507 PC Desktop
Compatibility Intel Celeron 2.66, ECS Elitegroup P4M800PRO-M3,
what is your motherboard name and version, send me your total computer quoation on my email address below...
good luck
Apr 12, 2009 | Intel Celeron, 2.6 GHz...
What RAM options for Elite Group 945g-m3 motherboard available?
Hiya Prodigalrich
the maximum you can put in this board is 2gb = 2 x 1gb sticks of speeds ddr2400/533 and 667 running in dual channel mode
hope this is of use
Feb 27, 2009 | EliteGroup 945G-M3 Motherboard
I would like to sapier vhich processor's are compattibble with my motherboard ECS P4M800-M (3 PCI, 1 AGP, 1 CNR, 2 DDR DIMM, Audio, Video, LAN)
Well there are probably hundreds of CPU's compatible with your motherboard. What you need to know is the kind of socket it has.
The most common are AM2(dualcore) and AM2+(quadcore) sockets.
You can just try some sites that let you build your own pc. if you then submit your motherboard there, in the next step you will get a list of ONLY cpu's that are compatible. But if you find one, you should still check.
You can find hundreds of sites just by googling "build costum pc" or something like that.
I hope this helps,
Feb 17, 2009 | ECS 945G-M3 (V3.0) Motherboard
Ecs 945g-m3 motherboard power switch pin location????????
I have found the manual for your motherboard, here is a link to the download from the manufacturers website.
I hope this helps,
Thanks for using FixYa,
Jan 21, 2009 | EliteGroup 945G-M3 Motherboard
EliteGroup 945G-M3 Motherboard Logo
619 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
