I pod software
I have windows 2000 professional and I can not seem to set up my ipod. Do I still need XP or something
Thanks
kevin
  • 667 Answers
Here is what Apple says about that: Tunes and QuickTime software for Windows require Windows 2000 with Service Pack 4, or Windows XP with Service Pack 2.
You can troubleshoot your issues here:
http://docs.info.apple.com/article.html?artnum=93976
Posted on Jan 13, 2008
Ipod nano 2gb cannot be synced required disk
1. Run "c:\WINDOWS\system32\devmgmt.msc" (this is the Device Manager), this will need to be used later, but you'll need it quickly when you do.
2. Start i Tunes
3. Connect i Pod
4. Go to your i Pod Settings and select "Enable disk use"
5. A dialog box will pop up reminding you that you'll need to manually eject. Hit OK
6. Hit Apply to save changes to the i Pod
7. Quickly switch to Device Manager window and right-click on any item there and select "Scan for hardware changes"
8. Switch back to i Tunes, where you should have a nice, working i Pod!
Let me know, if problem still persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 27, 2009 | Apple iPod nano
Tip
How to fix a error 48 with itunes
The message does not indicate that there is an issue with the iPod but that that iTunes was unable to read the iPod software update it uses to restore or update your iPod. You can delete the folder containing the iPod software update files so iTunes can download a new copy of the iPod software update.
Here are the steps to take if you get this message:
Eject iPod and quit iTunes.
Use Disk Utility in Mac OS X or run chkdsk in Windows to verify there are no other issues on your hard drive.
Locate the iPod Software Updates folder:
In Mac OS X, the folder is
/Users/username/Library/iTunes/iPod Software Updates
In Windows Vista, the folder is
C:\Users\username\AppData\Roaming\Apple Computer\iTunes\iPod Software Updates
In Windows XP and Windows 2000, the folder is
C:\Documents and Settings\yourusername\Application Data\Apple Computer\iTunes\iPod Software Updates
Note: If you don't see the files in Windows, turn on the Show hidden files option.
Windows Vista: Open Computer and choose Folder and Search Options from the Organize menu.
Windows XP and 2000: Open My Computer and click Folder Options from the Tools menu.
Click the View tab.
In the Advanced Settings pane, select the "Show hidden files and folders" button.
Click OK.
Drag the iPod Software Updates folder to the Trash or Recycle Bin.
Connect iPod and open iTunes. You will need to be connected to the Internet to download the files.
Then restore
on Apr 25, 2010 | Computers & Internet
Tip
How to fix error 48 in itunes
Click the View tab.
Click OK.
Then restore the ipod agin -
What are the basic applications that runs on Windows XP O/S?
well every application and software is built on on a platform that is compatiable with some certain operating system . u should have encounter some applications that run well in xp and vitsa but are not compatiable with win 9X and others . win xp also introduce a option of compatibility for applications . just right click a .exe file and go to properties there u will find some options . suppose if u have some application or software which were runing fine in win 9x and 2000 but seem not to work in win xp u can set option from compatibility than how the system should run the application and in what platform . if u choose win9x/2000 option the o/s will trick the software that actually its runing on win98/2000 . but it works in some cases . i hope u understand thankx and take care of urself
Jun 11, 2009 | Microsoft Windows XP Professional for PC
Grays songs in ipod when connected to Computer
You need to set your iPod to update manually, instead of syncing automatically when you plug it into the computer.
To do this, plug your iPod into your computer, and on the iPod info screen that pops up in iTunes when your iPod is connected, click "Manually Manage Files."
You'll now have to click and drag your songs from your library to your iPod, but now you can also play songs on your computer directly from your iPod and delete songs from your library without deleting them from your iPod at the same time.
Hope this helped!
Sep 05, 2008 | Apple iPod MA446LL/A MP3 Player
20GB IPOD
maybe...perhaps try changing your itunes setting
to
"manually update ipod" if it is set to autosync then all tunes in the library which are registered as being on the pod will automatically update. each time you connect the pod the itunes sw will update the pod from the library.
when the pod is connected and auto sync is active if you delete a tune from the lib it will update the pod and delete the same tune.
Apr 29, 2008 | Apple 20gb Ipod Mp3 Player With Click...
How to configure FTP server in windows xp prof ?
Setting up an FTP site Using Windows XP Professional Windows XP professional (as well as Windows 2000) includes Microsoft's IIS (Internet Information Server) which can be used to create an FTP site on your computer. It's a fair bit less complicated and less flexible than using some third-party FTP server software packages, so we will give you guides for setting up both. If you are using XP Home you will need to use third-party software. There is no way to publish an FTP site with the Home Edition of XP.
The first step is to check that IIS (Internet Information Services, Microsoft's web-server application) is configured properly.
Go to start\'control panel'\'add/remove programs'\ choose the 'add/remove windows components' button from the bar on the left. Highlight the item 'Internet information services (IIS)' If it is unchecked, check it, then click 'details.'
The components you will need are: 'common files,' 'file transfer protocol (FTP) service' and 'internet information services snap-in.' Uncheck any others then click next. IIS will configure itself, and you may be prompted for the XP CD.
Mar 21, 2008 | Microsoft Windows XP Professional x64...
Need proper software to download music from pc with windows 2000 to ipod
hello yroj28, have you downloaded I-Tunes from the disk which comes with the I-pod? If not, you need to download it.
hope this helps! rosebetts xxx
Dec 30, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Cd to ipod help
http://docs.info.apple.com/article.html?artnum=93506
Dec 24, 2007 | Dell Dimension 2400 PC Desktop
How to setup my ipod nano
it sounds like you might need to change some of the itunes settings. you open itunes and plug your pod in and see if it shows up on the left side of the window in with the playlists. if it doesn't then there is an interface problem which could be something as simple as the cable. if it does show up, then you click on that icon and you can change your pod settings.
Dec 18, 2007 | Apple iPod nano
 Grubhead
Grubhead
