Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Hard drive making strange alarm/chiming noise and won't load onto desktop
I have just plugged in my Lacie hard drive and it is making a strange sort of alarm/chime noise and will not load onto my desktop.
Can someone suggest what the problem is?
  • 8 more comments
  • charlottemil Jan 16, 2008
    It is a La Cie d2 Quadra external hard drive with both firewire 400, firewire 800 and USB 2.0 connections. It is about a year old, but hasn't been used a great deal so is still in impecable condition. Which is why I do not understand why it is making this strange noise. It isn't just a regular 'broken' sound, like clicking or anything. It plays a kind of alarm, which I can only assume is a bad thing and it fails to load onto the desktop. I am extremely worried as there is a lot of important data on there.
    I am assuming that the best thing to do is get a data retrieval done through LaCie. Or would anyone suggest another course of action?
  • Anonymous Jan 19, 2008
    having the exact same problem
  • Anonymous Feb 07, 2008
    Exact same problem..how do u fix it??
  • Anonymous Apr 04, 2008
    Very strange noise as if a electric motor or vacuum is on.
    After some time it shuts offf
  • deanern1 Aug 05, 2008
    I have the same exact problem!!!!!!!
  • koconnor Aug 10, 2008
    Same problem here too - it just started making an alarm sound.
  • snobbyking Aug 28, 2008
    Same problem here: hard drive not recognised and making a chiming noise
  • Anonymous Sep 06, 2008
    Reboot
  • Anonymous Sep 16, 2008
    Same problem,
    When turned-on, sounds as though disk begins to spin, fan turns-on... then everything stops, and it starts over again.
  • Anonymous Oct 24, 2008
    Same problem!!
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Posted on Sep 24, 2008
Same here, LaCie 500 GB, some strange sounds and its not showing anywhere on my XP. please if anyone have anything to help, just let me know, LaCie is the worst storage devices I ever used.
Posted on Sep 21, 2008
Yes i am having the same problem there shit
Posted on Feb 05, 2008
    Champion:
  • 207 Answers
That's strange to me!! I do believe that it is a hard drive, right? it is brand new?
Posted on Jan 16, 2008
6ya staff
SOURCE:
I purchased a LaCie Rikki Go Hi Speed USB 2.0 from Microcenter and had them back-up my old MAC hard drive info onto it. When I plugged it into my newer MAC, I copied the folders onto my newer desktop that...
It could be that your new mac has a newer operating system on it, so I think you should be using the new itego backup assistant from iomega see http://www.lacie.com/products/product.htm?id=10323 this tells you what it does and you can also download it from here as well
Hope this helps
Sep 14, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
Chiming Noise
GET THE SPEAKERS PIN REPLACED AND ENJOY
GIVE ME ALL THUMBS
GIVE ME VOTE
Jan 28, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 1 tb external hard drive won't work
ya .. put it for replacement and u get a new one for free .. just dont tell them u dropped it
Jan 10, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
Lacie desktop hard disk problem
The strange sounds you are hearing are the mechanical parts in the hard drive hitting the platters in the hard drive.
I would take it to a local repair center to see if they can recover any data. I wouldn’t mess with it too much as the hard drive runs the chances of a successful data recovery are decreased
About hard drive failure
http://en.wikipedia.org/wiki/Hard_disk_failure
I hope this info helps you in some way
Please rate
Thank you
Jon King
Aug 22, 2009 | LaCie (301015) 120 GB Hard Drive
My mac is not recognizing my Lacie 1 TB, it started a week ago. It used to work fine for 2 months or so. I got this Lacie less than 3 months ago. I have fully stored my all my music there, but now I can t...
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
Mar 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie Desktop Hard Disk beeps when connected
No much help I can give, when an hard drive beeps it has motor error or head error, the disk hardwar is faulty, and you are not able to recover anything from the disk.
A safe data recovery can only be performed by specialized companies on a facility called clean room, where dust is completely removed from the room using a vacuum.
The data recovery using this kind of equipment does not cost less than $800.
Nov 23, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie d2 Quadra 500 GB HD dropped, now makes strange chime/alarm
Modern hard drive motors can easily become seized after an impact. The only DIY solution I am aware of is the use of a heat gun over the back of the drive motor. The build up of heat within the motor is sometimes enough to free it.
If the drive was running the problem may be due to a phenomenon known as "sticktion" where the drive head is actually stuck to the disc surface. If this is true then you need a data recovery company.
Nov 19, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
3,168 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
