Question about Car Audio & Video
LCD screen in speedometer of 1989 Ford LTD ( car )is too faint to read
Is there a way that that LCD display can be made brighter? cant readthe speedo in the day time, & its not that flash at nighteither. Do you know the best way to solve this problem? can yousuggest suppliers of spare parts etc? many thanks Meredith ( )
  • 57 Answers
Only by fitting brighter backlight, but this is normally not that easy, depending on the size. Some backlights are part of the LCD assembly, on smaller units they are sometimes side mounted. The contrast on an LCD is usually adjustable - there may be a small potentiometer on it that will adjust the contrast, that may improve matters.
Posted on Jan 14, 2008
Is there a fuse for the speedometer on a 1989 f250
no, the cable may have stretched or snapped. Unscrew the speedo cable from the trans & see if it loosely slides out. If so, cable NG
Aug 20, 2017 | Ford Cars & Trucks
Yamaha wr450f speedo
it seems that you got some water into it, if it is not totally sealed unit you can clean it and remove the water residue, if it is a sealed unit, you will have to get a new speedo
Aug 14, 2014 | OEM 2008 Nissan Rogue Speedometer...
Will 175/70/13 tires fit 1989 plymouth horizon originally equipted with 185/80/13
They will fit the car but are 2 sizes shorter than original equipment. Will make it ride a little rougher, and may make the speedometer read faster than your actual speed. Probably not a huge effect on the speedo.
Aug 25, 2011 | 1989 Plymouth Horizon America
1985 454 LTD Kawasaki speedometer gauge needle won't move or register at what speed when driving down road.
hello check speedo cable, if not i belive these bikes speedos has small gears inside of speedometer, als check make sure cable is not broke on the ends
Mar 30, 2010 | kawasaki EN 500 Vulcan Classic Motorcycles
Can not read the screen--too dim
cant, its either the lcd itself or the lcd power inverter.
Mar 23, 2010 | Motorola Mobility MA351 Cordless Phone
Speedometer error?
Many cars have an error on the speed indicated. 10% sounds quite high, next time you buy tyres go for one size bigger or the next profile up, eg, if you are using 70 series go to 75 or 80. That will sort your problem out and you will get better fuel consumption. You can have the speedo calibrated but I would thing that the cost or effort wonuldn't justify the result.
Feb 27, 2010 | 2002 Toyota Camry
Speedometer Cable replacement
A universal kit will work for your application. Most of the time the center cable is what is damaged.
1. Remove speedometer cable from transmission
2. Remove speedo gear retainer and remove speedo gear.
3. Pull out cable from sheath - If broken you will only get part of it
4. Remove instrument panel and pull out section of cable still trapped in cable sheath if applicable.
For re install follow directions on package.
1. Cable appears un-damaged: Check to make sure the speedo gear is not damaged where the cable enters it. Then also check the back of the speedo head cable hole for damage.
2. You can measure you two broken pieces to arrive at an appropriate length for ordering purposes.
3. Make sure this is well lubricated on install otherwise the speedo can jump up and down or damage the new cable.
Feb 13, 2010 | 1989 Ford F 150
My 1988 Thunderbird speedometer digital read out too dim
hi,there is a special halogen bulb from the ford dealer that is brighter than the junk from the auto part stores.
Sep 03, 2009 | 1988 Ford Thunderbird
1989 Honda Accord speedometer not working. What is a speedo head?
The speedo head or cluster is the part that houses the speedometer and tach, etc. now it may be the speedo cable that comes from the transmission to the speedo head that has broken. If so replace the cable and your back in business. If it is the head you can get them from your local recycle yard.
May 29, 2009 | 1989 Honda Accord 4 Door
Faint white spots on macbook pro lcd screen
If the spots remain in the same place I'm sorry to say no. Be careful what you clean the screen with. I'm a fan of a warm wet damp only rag. Using alcohol or other cleaners may damage the surface. There are also cleaners available at local stores. You don't need anti-static on an LCD display. The spots can be from pressure on the display applied at some point even if that pressure happens when closing or transpoting your laptop.There is no way to fix it.
Sep 18, 2008 | Computers & Internet
Car Audio & Video Logo
169 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
