Does the unit play in vinyl mode if you turn the platter by hand?. If this the case the commom fault in the "sheet switch" which is under the platter and sensors the pressure when you press the platter.
The "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it (i.e something is sat on it for a long time), it tends to stick together giving the effect you are pressing it when you're not.
The part will cost you about £30.00 + fitting - unless you are confident enough to do it yourself
email me if you would like to order one.
[email protected]http://stores.ebay.co.uk/methleykev
