Question about ASUS m6n Notebook
Ram upgrade I assume the second module is under the keyboard on my Asus M6000 (M6B00A) laptop but cannot see how toget to it. Any help would be greatly appreciated. Bryan Smith.
  • HELBRY Jan 14, 2008
    One chip is on the bottom but the other is beneath the keyboard. I removed the 2 "K" screws but still no luck with the keyboard. Could not detect any tabs around the edge of the keyboard. Thanks.
    Sorry, did not even see the web site pointer when I first read your post. Problem solved and many thanks. I had been looking for M6000 info not z70 without any luck. Thank you once again.
    Problem Solver:
  • 14 Answers
Most laptops have a compartment with a led held by a screw on the bottom of the laptop, look under there, typically 1 or 2, RAM and/or Harddrive
Posted on Jan 14, 2008
The taps are on the top theirs 3 of them under F1 F8 and INS
Posted on Feb 28, 2008
6ya staff
SOURCE:
Need to know how to install additional ram
There is a little door under the laptop, with a couple screws.
If you open it, you will see the ram modules.
They are easy to remove and replace with additional (if empty slot available) or upgraded ram.
Aug 08, 2011 | ASUS Computers & Internet
Hi, I would like to upgrade the original 512 MB memory. We have just found the second slot (just under the keyboard!!!) and now I have the following question: can I keep the old 512 MB RAM module and...
What type of RAM is your Pc using? SDR, DDR1 or DDR2? 1 GB single module of RAM maight be heavier for your notepad and the Laptop maight even fail to boot. Just use the 2 Modules of Ram (2 chips each 512MB) and check in BIOS if the RAM capacity has acually changed.
Rgds
Nov 04, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I can only find one slot for a RAM module, under the memory bay door on the bottom of the machine, but the Crucial site says there are two slots. A system info readout for it says I have 512 of RAM but the...
The other memory slot is under the keyboard. Below is the service manual that has the full disassembly instructions for thelaptop. You can see the memory module installation on page 83. Just follow the guide on keyboard removal, the slot will be visible when the keyboard is removed.
http://tim.id.au/laptops/thinkpad/T40-T40p-T41-T41p-T42-T42p.pdf
Nov 04, 2009 | IBM ThinkPad T40 2373 Notebook
Where is the ram positioned in the pc Asus M6000
The RAM compartment for the Asus M6000 series notebooks could be accessed by turning the notebook upside down. You will find in the middle of the down-side a cover with 2 screws. If you unscrew these 2 screws, you can access the RAM slots.
Jul 12, 2009 | Computers & Internet
I can't find the second ram slot
Lots of laptops have the second slot under the keyboard. If you are adventurous take the keyboard off and look in there.
Mar 11, 2009 | Evesham Computers & Internet
Asus g2p max ram
You got two memory ports. One on the bottom of the unit.The second one is on top of your Notebook. To reach it you have to remove the keyboard. There are three small points on the top of the keyboard to unlock it. Under the keyboard you will find a metal protector with one screw which protects the second ram...
By the way: The Bios only recognizes up to 2 of ram.
System Profile ASUS G2P Standard Memory 0 MB (removable) Maximum Memory 2.0 GB Slots 2 sockets System Notes PC2-4200/5300 DDR2 SDRAM SODIMMs
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2008 | ASUS G2P Notebook
Where is the expansion slot for the RAM for ASUS Notebook A2400H?
The manual is incorrect. Memory is under keyboard. There is a small hole to the left of the right speaker. insert a paperclip vertically into the hole and apply a slight amount of pressure at the same time sliding the plastic section to the left. It should be obvious at this stage. then fold back keyboard. 2 memory slots are located under the plate near the middle of the unit. Specs say max of 2 x 512MB modules. they are PC2100 DDR266 200 pin SODIMM. If there is someone else reading this maybe they can tell me what the slot is for under the smaller plate to the right of the memory compartment.
Cheers.
Aug 06, 2008 | ASUS A2H (A2HOB) Barebone
Where are the ram chips located on balance cn 1401? i would like to upgrade my memory.hwo do i do it?
usually under the bottom of the laptop there are some covers, the memory will be under one of them. To see what to look for follow this link: http://img.zdnet.com/techDirectory/_MEMMOD.GIF To find a compatible module run the tool from crucial http://www.crucial.com/systemscanner/index.aspx
Jun 21, 2008 | Balance CN1401 Notebook
Accessing memory (RAM) to upgrade
First of all, remove the battery
Insert a thin object under the securing strip and lift it up.
Be careful, it may be very tight.
Remove the securing strip.
Carefully work with finger to disengage plastic latches securing the securing strip.
Remove three screws and a metal brace securing the keyboard.
Lift off the keyboard and place it on the palmrest
Now you can access the memory modules.
Jun 12, 2008 | Toshiba Satellite A25-S207 Notebook
ASUS m6n Notebook Logo
513 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
