Nvidia GeForce 9500 GT,  PCI Express Video Card Logo
Posted on Nov 24, 2009
ECS GEFORCE 9500 GT 1GB PCI-E COULD NOT RUN ANY GAME AT ALL. IT GOES BLACK EVERY 3 SECONDS AND ON THE THIRD, IT JUST BLACKED OUT.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 25, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
11943
Points
16
Dude look at ur resolution.
  • rexyflexx_14 Jan 08, 2011
    i even tried to set my res at 800x600 bro, still got the same f*
3helpful
I need geforce drivers 9500 gt driver for xp sp3 32bit.
download it through google site i.e download geforce driver 9500 gt driver for xp sp3 32 bit
2answers
Geforce 9500 gt out put black & white why
1..Check your VGA to monitor cable or change it with a new one.
2..Check to see if there are any jumpers (switches) on the card and are in correct position (see the card's manual).
3..Connect another monitor to your PC.
4..Take out the VGA card check if there are any signs of wear in the VGA monitor connector or to the PCI express to Motherboard connector, put it back again, insure it is placed correctly.
2answers
My graphics card is GeForce 9400 GT 1gb and whwn i play IGI 1 the screen gets blurred nothing can be seen my motherboard is of gigabyte
try these following steps:
1: update your graphics driver to one of the most recent one:
2: Lower down the hardware acceleration to minimum.
3: If you can see things in the pause menu of the game please disable all the extra graphics effect ( like anty aliasing, etc )
Hope this would help.
8helpful
3answers
Where i can dowload driver of Nvidia Geforce GT 1gb (NS-GF9500GT) for windows 7 64-bit
Please go to this link and click Download the Latest Driver
http://www.nvidia.com/object/product_geforce_9500gt_us.html
1helpful
I recently installed the latest drivers for an nvidia gforce 8500 gt card, and now every single game i try to play crashes. after a few minutes into the game (any game), the monitor goes black, and then...
Not an unusual situation. Try older drivers for the card. You have a couple of options.
1) If you're running a later Windows version, you can revert to earlier drivers with a System Restore. There should be a Help and Support option under your start menu, use that to revert to a time prior to when you updated your drivers.
2) If the last set of drivers you've installed worked, under Windows Explorer, you should have a C:\NVIDIA\DisplayDriver\ folder. Look for a setup.exe file under the fileset before the latest set of drivers, and run that. It should revert you to the driver version that last worked for you.
3) If all else fails, browse to www.nvidia.com, select your region, and from the Download Drivers dropdown, select 'Beta and Archived Drivers'. Select the appropriate settings for your OS and video card, and click 'Search'. You'll find older drivers for your system there. Keep installing older driver versions and test games until you find a driver that works for you.
Nvidia geforce 9500 gt tv output is black and white
generally people plug the tv into the round socket called svid.
I have: dg31pr core2duo 2giga memory kingston 320hd nvidia geforce 9500 gt 512 Problem: When starts operational system (Vista or 7),sometimes the video do not open. Bios in Auto or pci Express
Suggest you test your geforce 9500 GT in another system or try another PCI-Express video card. Try cleaning the contacts of your 9500 GT with alcohol, allow it to dry. Do not touch the contacts with your fingers after cleaning. If your onboard graphics functions correctly than it may be the 9500 that has a problem.
Happy holidays!
Mike
Where does the cable go to on main board from MSI Geforce 9500 GT it's to wires but a 3 prong plug. Is it for the fan?
yes is for the fan you can cut the connector if the pins aren't allready next to each other. yel or red is allways + in a pc
Top Nvidia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
