Question about Soltek SL-75FRV Motherboard
I can't download BIOS update utility + .rom file
Both Soltek's sites (in Taiwan and Germany) are in down, where is it possible to find subject for Soltek SL-75FRV? I got multiple hardware troubles and decided to begin with BIOS update, but can't find it on the internet
    President:
  • 2,351 Answers
Try here:
http://www.updrivers.com/search/SL-75FRV
Bios only. All most nill for other drivers. Luck!
Please vote!
Posted on Jan 17, 2008
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Bios file
SOLTEK has gone bankrupt -- their web-site is "down".
So, there is _NO_ support (BIOS-update, drivers, replacement parts) available at all.
May 18, 2009 | Soltek SL-K8M800I-RL Motherboard
Latest bios update and drivers for Soltek SL-85DR3-C rev:A3 silver PCB
SOLTEK has gone bankrupt.
Their web-site is "down".
So, there is *NO* "support" available from SOLTEK.
I am not a lawyer, but since DRIVER GUIDE is offering a service for a fee, it probably is legal for them to charge a fee.
Jan 11, 2009 | Soltek SL-85DRC Motherboard
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
FLASH BIOS Update
http://www.techspot.com/drivers/driver/file/information/2442/ looks lika good page for you. The link above goes directly to the download site.
http://www.charydent.com/sl-75kav-x.html is another site, as above it takes you directly to the download part.
Hope these direct links help.
Jul 05, 2008 | Computers & Internet
Bios update
go to site dl it run it should auto do itself or install on floppy ok then boot into flooppy 1st tell bios floppy 1st ok or cd ect ok
Feb 11, 2008 | Soltek SL-915G Pro-FGR Motherboard
Mstr2kx
This is a tough one. It looks like they have let their website go down hill. Try calling them. Here are the numbers they have listed.
Rotterdam, The Netherlands
Tel 31-(0)10-245-7492 Fax 31-(0)10-245-7493
Taipei-Hsien, Taiwan
Tel +886 2-2642-9060 Fax +886 2-2642-9065
Dec 02, 2007 | Soltek SL-85DRC Motherboard
Soltek 85miv3 drivers
You can download all your drivers from soltek.de/soltek because the company is based in Germany but also in Taiwan. Thanks
Goodluck to both of you let me know how you go.
Regards
Nov 03, 2007 | Soltek SL-K8M800I-RL Motherboard
Soltek SL-K8AN2E motherboard
http://www.soltek.de/soltek/download/index.php Once they fix their website, that should give you the files you're looking for.
Oct 01, 2007 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Soltek SL-75FRV Motherboard Logo
333 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
David
David
Paul Bade
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
