Buzzing from speakers
I have a sony str db1080 Reciever amp its about 5 yrs old. It has started making a buzzing from teh speaker channels. I have tidied up all wires and have tried switcing off all potential interference sources like TV Sat box etc. but it makes no difference. The sound gets louder when the volume is increased. I have noticed that the longer the amp stays on the sound diminishes.
Can anyone help?
    Scholar:
  • 70 Answers
First, let's distinguish a buzz from a hum. A hum is a clean, 60 cycle signal that sound like a tone. A buzz is 60 cycle noise created when the power filtering circuit is not doing it's job. This is basically a 60 cycle hum, but because of the way the faulty filter reacts, it "distorts" the signal slighly and is a buzz. Trust me on this if you don't want a full electronic explanation. If you are curious and would like one, email me seperately.
If it is a buzz, chances it is the filter capacitors, but lets not jump to that conclusion yet, this can only be fixed by a professional, so let's try the free fixes first!
You might have 1) a ground loop, 2) faulty house AC. What is the age of your house? Are you using any three prong to two prong adapter? If so get ride of them.
But the first obvious thing is to look inside the unit and see how dusty it is. UNPLUG FROM WALL before opening. Use a can of compressed air if necessary. Now try. Dust build-up causes static electricity with can play havoc with electronic componenets, but normally not 60Hz, but it's worth a try.
Before I get into the ground loop, do you have any flouescent lights in the area? These use transformers which tend to put a 60Hz buzz through wiring it is directly attached to, but only when on.
Check if this buzz is consistant with any selected device (DVD, CD, Radio, etc.). If it is true of all, continue on, if of one, disconnect that particular device and see if it stops. Just turning off a device still keeps it in the elctrical loop...
A ground loop can be caused by a broken wire. It is important that every compnent be grounded to a single point. With a broken wire this can cause multiple paths to ground. disconnect everything, all components from the receiver, antennas, any cable running to another component, etc Just leave the main speakers hooked to the receiver and turn it on. Hopefully you have "audio snow" but no buzz. This method is called isolating the problem. If the buzz disappears skip to the 2nd paragraph. If you still have a buzz: unplug unit from wall, try a 3-2adapter into the wall. If this works, you have a faulty ground. Bring receiver into another room and try. Same result with buzz? (with or without 3-2). Go to a hardware store and purchase a ground fault indicator and make sure your house wiring is OK. Very inexpensive part. You simply plug it in a the lights tell the story. Usually two yellow lights and one red. Both yellow on indicate everything is fine.
Up until this point I am taking it for granted tht the power cord from the receiveris three pronged. If it is NOT, try running a thin wire from the outlet (attach using the center screw that hold the outlet cover in place) to a screw on the receiver. It would not hurt to try this even if it is a three pronged connector in case there is a broken ground within the unit.
Hook up and test each component until you hit the one the causes the buzz. When this happens, try using a different cable as this one is probably broken. If it doesn't stop, try what we tried for the receiver, if it is a three prong electrical plug, use a 3-2 adapter, still buzzing, now try adding the extra thin wire between the two compnents.If it a two prong, add the ground wire from the component to the receiver.
If all else fails it needs to go into the shop. But I will say this. Compare the cost of getting an estimate/repair with purchasing a new unit. It might actually be less...
Hope this helps,
Jeff
Posted on Jan 14, 2008
  • 979 Answers
Bad filter caps. Have them changed out and see if that helps..accordianman
  • 45 Answers
Sounds like a capacitor is taking a long time to do it's job. You might want to see how much it would cost to repair.
SW-910, blown speaker or ? makes rattle/buzz sound. replace speaker and/or change to passive type sw?
i would suggest replacing it rather than fixing. The cost of the repair will be about the same.
if you went to a passive sub/seperate power amp setup you could get a much higher quality unit, but it would cost you considerably more cash.
Feb 01, 2015 | Sony Audio Players & Recorders
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
Why is the subwoofer making a buzzing sound? Is there a solution?
I have had the same problem with my Sony sub. It sounds like it is picking up electrical noise and would not go into standby when the reciever was off. I rerouted my wires and changed to a much higher quality wire. I was using a very low quality stranded copper with thin insulation to start with.
Jun 14, 2010 | Sony SA-WM20 Subwoofer
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
Loud buzzing at the first volume setting
Check all your wires and make sure that none of the wires that are powering any equipment (including extension cords, power bars, and power cables on the unit itself) are running parallel to any of the audio cables going to your speakers or from your inputs to your unit. This could be what's called AC hum, which is caused when the electrical current causes interference that gets picked up by the audio cables and amplified by your system. Just make sure you move the power cords as far away as possible from the audio cables.
Jan 08, 2009 | Sony STR-DE345 Receiver
Can't get surround sound when watching tv
your RCA on your tv is acting like its in mono..it may be a problem with the jacks.  alternatively..you can buy a splitter and split teh side that sounds stronger (L) or (R) with a male to 2 female spliter out of the tv then back into l/r input on your reciever... It wont give you surround stereo...but it will soudn a whole lot better.
Nov 08, 2008 | Sony STR-DG800 Receiver
Hook up problems
either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Jan 02, 2008 | Sony STR-DE835 Receiver
811 people viewed this question
 Grubhead
Grubhead
