Question about Cameras
Lines in AG-dp800h
Lines appear on the view finder when the camera is switched on. Before I begin to record I have to turn the camera on for about 15 minutes then the lines disappear. A technician told me it may be that the pulse power board may need replacing. Is he correct or is there another solution. I searched online for this board but cannot find it. If you can locate it please let me know the part number so that I can have this problem solved.
  • dcac May 24, 2008
    my camera has lines going down you can not see anything but a white screen and unable to see a picture
    Genius:
  • 2,985 Answers
What ever the reason for the problem- generally speaking getting a camera repaired is a no no
Like many small electronic items they are made in such a way that human intervention is not possible.
The only recommendation is to contact the the vendor for replacement if still under warranty or manufacturer if out side
From time to time there are issue with certain components- where a free replacement may be forthcoming.
Posted on Jan 14, 2008
There is a line appearing from the center of the view finder till the end. This comes on only when the camera is switched on
if the line came in photos when you seen them from PC then its a Camera CCD fault, Or If the photo clear in PC view then its a LCD fault.
Aug 04, 2012 | Nikon D70S Digital Camera with AF 28-80mm...
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
Lines are coming up on the screen, but we have checked the viewfinder etc
Sorry cant fix this for you, but can give you some info....!
I have the same camera, and must say i love it.
But the problems you are having (and myself) since last may are due to a capacitor fault, somewhere inside.
Parts are cheap to replace (about £0.20) per blown capacitor... The cost comes from the labour charged for finding these tricky little devils!
Apr 22, 2010 | Panasonic AG-DP800H Camcorder
Supercam ah dp800h powers on but nothing in the view finder
most likely problem is many defective capacitors on the video board.
Mar 02, 2009 | Panasonic AG-DP800H Camcorder
Lines in AG-dp800h
Hello all!!
I found the solution!!
3 electro chemical capacity in the 3700 series on the camera head board.
change the chemical rear the DAC and above the ADC for process digital signal.
The name of the capacity: c3 c6 c9 in the 3700 section on process board.
The capacity is a part of filter the reference signal out of the DAC for ADC reference for ic1 ic2 ic3...
If the capacity is dead a sinusoidal signal appear for the red blue and green reference voltage and the result is a parasit signal into all camera.
You can measure a 50khz signal on the composite video signal.
Best regards
Phil_F
Jan 13, 2008 | Panasonic AG-DP800H Camcorder
Problem Supercam AG-Dp 800heg
Hello Situ,
If you must Change the erasing head's supply filter (capaciter) then change the audio erasing Bios OSC, transformer supply filter tantlem capaciter, the problem will be clear.
Regards,
Muthu.M
myesak_14@yahoo.co.in
Jan 04, 2008 | Panasonic AG-DP800H Camcorder
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Panasonic DVC 7
Clean the heads with a Panasonic MiniDV cleaning tape. I've seen many cameras come through our shop with this problem - a quick cleaning made a world of difference.
Mar 13, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Cameras Logo
76 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
