Question about Coffee Grinders
Nissan primera clutch
How do i adjust clutch on 1.6 petrol primera
0 characters
1 Points
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Just bought a used one, seems like the espresso grind is pretty course, is there an adjustment I can make?
To adjust this grinder turn the adjustment nob to the finest setting (ESPRESSO or TURKISH) Locate 2 small set screws on the adjusting nob. Loosen these screws (do not remove them) about one full turn. Start the grinder and, with it running, VERY SLOWLY and GRADUALLY, turn the CENTER adjustment screw clockwise until you begin to hear the burrs begin to touch (whirring sound). Back off the center screw about 1/16 of a turn, shut of grinder and re-tighten the set screws. Then try the grind on DRIP or there about for brewed coffee.
May 21, 2010 | Grindmaster 495 Electric Grinder
With the dial turned to "Turkish" I still get a very course grind. How to adjust/fix?
On the adjusting knob there are 2 set screws (outside of the center) and an adjustment screw (the one in the middle). First make sure the LARGE screws on the side of the SELECTOR plate are tight. Start with the selector on Turkish, with the grinder OFF loosen the set screws about one full turn each. Leaving the selector on Turkish turn the grinder on and gradually VERY SLOWLY turn the center screw clockwise. Eventually you will hear the burrs inside touching. After they touch back of the center screw about 1/8 of a turn. Tighten the SET SCREWS tight as they may allow the grinder to go out of adjustment if not tight. Test the grind with very little coffee and throw those grounds out. Then grind and brew! If these grinders are adjusted too fine you may have problems with the grinds not falling and may back up.
Apr 26, 2010 | Grindmaster 810 Electric Burr Grinder
Grind is like powder
There are 3 springs in the holes around the top neck of the machine, the top part which sits under the collar adjustment knob.
Mar 28, 2010 | Mazzer Grinder-doser MINI
Extremely course grind
Remove bean hopper, clear chamber of all beans, either by grinding or using a vac cleaner, then turn adjustment collar finer until it cannot move, then back it up about 1/4 to 1/2 a turn. That should give you a good starting point on your grind.
Oct 04, 2009 | La Pavoni ZIP Auto Electric Grinder
Instruction manual for cuisinart auto grinb and brew 1 to 4 cups
Here is the trick with the Cuisinart Grind n Brews - their proportion sizes are based on a 5 oz cup - most coffee cups are about 8 oz cups - so you really need to use more than they suggest, but here is their reccomendation:
We recommend you use 1 scoop of whole
beans per cup. Maximum 14 scoops.
For 1 or 2 cups, use 1-1/2 level scoops
per cup. Adjust the recipe according
to individual taste.
Mar 25, 2009 | Cuisinart Coffee Grinders
Where to read the settings of the grinder?
If you cannot find a small arrow anywhere on the front of the grinder, just below the adjustment ring then, get a marker and pick a spot. That will be your reference point and adjust your grind from there.
Feb 26, 2009 | Macap MC4 Electric Grinder
Adjusting grind on Rancilio Rocky
  1. because it didn't work a wilde the upper burr holder could be jammed, carefully take id off, clean it good and then put it back until you touch lower burr with the upper.
  2. to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean grinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Dec 09, 2008 | Rancilio Rocky Espresso Coffee Grinder -...
2001 nissan primera p11 144 dash bulb replacement
Hi have a nice day.
Disconnect the battery cable first. Then, remove the trim around the instruments. You will probably need to drop the steering column to get access
good Luck !
Jan 11, 2008 | Coffee Grinders
04 nissan primera 1.8 radio
you have a nats system fault re-code keys or disconnect battery for 24 hrs
Jan 07, 2008 | Coffee Grinders
Coffee Grinders Logo
381 people viewed this question
Top Coffee Grinders Experts
Ernest R
Ernest R
Tony R.
Tony R.
Are you a Coffee Grinder Expert? Answer questions, earn points and help others
