Nintendo Wii Console
Problem for Nintendo Wii Console
Wii remote
By henro on Jan 13, 2008
hi my son's wii remote works on the menu screen and all other things. The problem comes when you start a game, say tennis or golf, and it won't let you swing at all. We bought it for him for xmas and it was working fine till a few days ago. I have totally turned off the system and reconnected everything but it still persists. any suggestions??
Cheers Trent
thenrickson@bigpond.com
Comments:
Jan 15, 2008
- i rang nintendo.they said-
remove remote batteries
turn on Wii console
hold sync button on console for 20 secs
turn off Wii console
unplug the power cable from the Wii and the wall
wait 10 secs
plug back in
turn on console
place batteries back in remote
hold down both sync button on console and on the remote for 2secs
press the A button on the remote
They said 9/10 times this works.......
guess i'm that 1 that doesn't!!!!!!
Same Problem
Dec 11, 2008
-   I had the exact same problem and it happened shortly after getting the Wii. But I tried banging the remotes a few times as was suggested and it worked!!! For both of my remotes! I am so happy, because I had tried everything else, and we had resigned to not using the Wii until we could pay to get it serviced. Now it's good as new!! -   mchelle1226
Feb 03, 2008
-   The same. I can use the remote on the menu screen but when it comes to playing a game -no chance. My other remote works absolutely fine.
Rachel G-   gafs
Feb 02, 2008
-   ever time i want to play a game one of the remote dose not work the finger on the screen seems to be upside down please help me-   Guest
Jan 31, 2008
-   hi was having trouble with what i thought was the sensor bar - ie the exact problems you have been describing- i went and bought a new sensor bar and it worked for maybe a month then the same problems - surely this is a major fault within the console????? i certainly cant afford to go buy a new bar every month!! i found this happened with every game and not just a select few still waiting for an email from nintendo-   bosley006
Jan 14, 2008
-   Having exactly the same problem, any ideas?
Tried new batteries, re-synching, scouring the net....help!!!-   Homerunner
Best Solution
posted on Feb 03, 2008
Very Helpful)
gafs
Rank: Apprentice
Rating: 100%, 2 votes
I tried the bagging on a surface as posted before and it worked for me too!
Was this helpful?
Yes
No
Solution #2
posted on Jan 31, 2008
Very Helpful)
bosley006
Rank: Apprentice
Rating: 100%, 1 votes
hi i posted the same problems as what you have described. i then read the solutions posted (the turn off and re-sync the machine) and it worked perfectly cheers!!! wished i had looked at trouble-shooting the machine before i spent a tenner on a new sensor bar!!!!
Was this helpful?
Yes
No
Solution #3
posted on Jan 28, 2008
Very Helpful)
XcorvenX
Rank: Apprentice
Rating: 98%, 9 votes
Turn the remote on each side and wack it on your palm three times each side. Don't kill it, just hard enough to loosen the sensor...its stuck.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
Helpful)
NicksDad57
Rank: Apprentice
Rating: 91%, 5 votes
Had same problem. Remote would not sense motion. Took battery out then put back in. Then smacked it firmly, but not hard enough to break it 3 to 4 times on a hard surface.
That did the trick! Bowled a 160!
My son has two remotes so I guess if you don't play two player games a lot you should swap remotes every so often to keep the motion sensor limber.
Was this helpful?
Yes
No
Solution #5
posted on Jan 15, 2008
Helpful)
RanDad
Rank: Apprentice
Rating: 84%, 11 votes
Hi, we're having the same problem as above...has anyone gotten this to work ? Sensor works while directing set up and choices, but no action when it comes to playing the games. Please advise, thank you.
Was this helpful?
Yes
No
Solution #6
posted on Jul 31, 2009
Not Rated)
spud12345
Rank: Apprentice
Rating: 0%, 0 votes
Hey none of the fancy reset directions worked for me either, but I GOT IT TO WORK by banging it - 2-3 times on the right side in my palm, then 2-3 times on the left side in my palm. (Geesh... what kind of board did I just write that on??) Anyway, just whack away! It took a couple rounds of this whacking, but it did fix it. I had bought my remote second-hand off of eBay and was bummed I got a bad one, but this resolved the issue quite nicely and now I can kick three of my friends' butts in Mario Kart instead of just 2 at a time!
Was this helpful?
Yes
No
Solution #7
Not Rated)
Homerunner
Rank: Apprentice
Rating: 0%, 0 votes
Thank you sooooo much Henro, we have our Wii back.
This has 100% worked for us, and it is even easier to control aswell.
Fantastic!!!
Was this helpful?
Yes
No
Popular Solutions for Nintendo Wii Console
Questions and Unsolved Problems for Nintendo Wii Console
Do you recommend Nintendo Wii Console?
Answer
Answer
We bought our wii two years ago, at the time of release but for the last year we have been unable to... (More)
Answer
my wii wont go into stanby mode for charging it goes straight to off ????????? help !
Answer
my wii only works in black and white. How can I correct this?
Answer
My Wii is refusing to turn on, even though it is hooked properly. No lights turn on, nothing. I... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 13, 2008
Same problem today. We tried re-syncing the remote. We took the batteries out and reloaded. It still won't swing.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
