Toshiba 57H83 57" Rear Projection HDTV Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The tv is blurry most of the time and gets horizontal lines...and then it'll snap into good picture every once and awhile...but mostly blurry
Chi Chu
Level 3:
  • Toshiba Master 8,457 Answers
  • Posted on Nov 24, 2009
Chi Chu
Toshiba Master
Level 3:
Answers
8457
Questions
0
Helped
2822876
Points
26282
Ur cocnvergence it dead,know how to solders,buy convergence kit.Tv repair World.com,Tv repair kits.
Blurry Picture on Toshiba 65HX81
yes the tv has convergence problem u will need a tech to reposition it
Ok well i have a Hitachi 50v500a i have had the light engine replaced about a year ago with no issues, but now when i power up the tv it starts fine but when the picture comes on there are blurry...
Sir try to check if there is a loosed connection in the light engine or cold solder in the electronic circuit board, this loosed connection cause your unit to malfunction, or the light engine of your unit is getting faulty. Good day sir and best regards.
1helpful
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
5helpful
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
A thin horizontal blurry line
Most likely it's the LCD panel failure.
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Picture fuzzy
hi dear
sound like to me it's screen voltage too hi check some cap on CRT base value 1mf 200v or above.at the same time u can check the cap on horrizantel 2.2mf 250/300/450vot some wear .have good luk
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
