Question about Vizio Gallevia GV42LF 42 in. LCD Television
Vizio in stand by (amber lights) mode on monitor
Remote turns on monitor, but cannot turn monitor off with remote, have to unplug from outlet to power off tv. LED lights stay amber on monitor (no flashing) and remote control glows amber when any button is pushed. Cannot turn tv on or off manually.
Thank you for any help!
  • 2 more comments
  • phins74 Jan 15, 2008
    One button controls on/off. When I unplug the tv from outlet and plug the tv back in I can turn the tv on with the remote, but I cannot turn the tv off with the remote. All led lights remain amber in color.
    Thanks for any help.
  • Anonymous Feb 16, 2008
    Same problem! Trying to use a universal remote. Haven't found a remote with Vizio code numbers!
    It turns on... but it doesn't turn off! Tried several time re-entering the code from manuel book help for a minute but them No turning OFF!
    I think it might be the TV and not the remote!
    Please advise
  • Anonymous Oct 25, 2008
    My Vizio suddenly stopped working. I can not turn it off or on with remote. By unplugging the power cord , I was able to turn it on with remote .TV still does not work. Lights on the touchpanel stays amber .I can not even turn it on/off manually either.
  • dsatele Nov 06, 2008
    i have the same exact problem - if i could get a diagnosis, i could probably fix it myself. please help!!
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Posted on Jan 14, 2008
Repairing lcd tv
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 21, 2016 | Vizio Vf550m 55-inch Full Hd 1080p 120 Hz...
42" Vizio tv. It turns on and turns right back off. It worked perfectly fine until my cat jumped on the remote and now I have no idea what's wrong with it. I think it can be fixed if anyone knows anything...
1. pull battery from remote for 10 seconds. This will force reboot of remote. test, if fail move ahead,
2. do a main reset on Tv,, pull power plug from power source,, wait 10 seconds, reconnect, turn on!, fail continue
3. ? when you turn on TV is the stand by led light amber, when you turn on LED\'s does it start to change color , but standby light is still on? if test positive with findings issue should be your motherboard or even power board but it should be Mo/Bo..
Jun 24, 2014 | Vizio 42 in. LCD TV
Vizio remote won't control tv
I just had the same problem. I call Vizio and this is what they had me do that did fix the problem.
1. Unplug the TV
2. Hold down the power button on the TV for 30 seconds (yes, with it unplugged and do not plug it back in yet.)
3. Take the batteries out of the remote.
4. Press each button remote twice to ensure that they bounce back and are not stuck.
5. Place new batteries into the remote.
6. Plug the TV back in. Not into a power strip if possible. ( I did not have an available outlet so I used a power strip.)
7. Try turning the TV on using the remote. (My TV turned on. All of the functions worked - problem fixed.)
Hope that this helps.
Nov 17, 2013 | Vizio New Original M3D550KD Remote Control
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
Vizio GV47L...when i turn on the tv, the screen stays black. The vizio light turns white and it makes the click noise like normal but after a minute of it doing nothing the light turns back to amber. I can...
the capacitors on the power board would cause the issues you are having. If you look at the capacitors and they look swollen , then they are probably bad.
Jun 06, 2017 | Televison & Video
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
May 11, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
828 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
