Related Tags:
This problem should be removed because:
Problem with Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
color is off, bue will not line up,yellow and
color is off, blue will not line up when resrtting colors ,yellow and blue shadows on screen
Solutions (1)
OK, I know this set very well--if convergence in the customer menu is
skewed and red or blue will not adjust in some direction, you have a
convergence problem.
I can give you (post here) START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
It requires that you are able to solder etc---not real hard even if you have never done it before.
Considering you can buy the parts on Ebay
for about 20 dollars if you can do it yourself or know someone who can
do it for you--you can save the set and a lot of money......most shops
get 300 or more for this kind of trouble.
If you want the instructions let me know and I will post them.
I can tell you the best place to get the chips--this set uses two STK-392-110 CHIPS.
Usually just both chips need to be replaced and the set adjusted.
The instructions tell you everything you will need and how to do the fix.
I composed them from my own experience and because many people here ask the same thing you did.
If you have questions etc, let me know. I am here to help people.
If this has helped you, rate this solution as I do this here for free.
Thank you for using Fixya.
SD TECH
Yellow and Blue shadow on left side of screen
My Toshibas rear projection TV - on the left side (in the middle of the screen), we are getting a yellow and blue "shadow" on most...
Phillips HDTV Projection TV. Colors don't...
Phillips HDTV Projection TV. Screen around 43 to 50 inches. Turns on and works, but colors don't line up creating a shadow affect....
The Panasonic mod# pt-47wx49e has started to have
The Panasonic mod# pt-47wx49e has started to have a blue and a yellow shadow on the right side of the screen. the rest of the screen is...
blue shadows and a yellow
blue shadows and a yellow and blue arc acroos the bottom of the screen
Add Your Solution
Panasonic 47" Rear Projection HDTV: Screen...
Whenever we try and play our XBox, we can't see the full screen because it's blown up. We've...
Why won't my TV's blue convergence move...
I recently received a Panasonic PT47WX54J TV. At first it wouldn't turn on, and would only blink. Now it turns...
i have sound but no picture all three lights do...
there is power but no picture i cleaned the mirror but the green blue and red light does not come on
I have a PT-47WX54J Panasonic TV I hvae no pic
i have no picture only sound how do i get a picture
How to replace pt-47wx54j lamps
We have all three lamps, and the green is the one not working. Im looking for instructions on how to remove the old lamp...
See all Panasonic PT-47WX53 47 in. Rear Projection HDTV Problems
Fix-O-Meter
58
58 people viewed this problem
- 0 people are following this problem. Be the first!
Top Panasonic Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
