This problem should be removed because:
Problem with Fisher Receivers
I have a Fisher RS-717 stereo receiver, amplifier. The speaker connections are channel A left & right and channel B left & right. The question is, can you connect speakers to just one channel
without connecting speakers to the other channel? Seems like I have heard doing that will do something bad to the unused channel, like burn it out.
Solutions (1)
Best Solution
Yes you can use either A or B without a problem. The restriction is when you have both A & B connected. In that case, the speakers MUST be a minimum of 8 Ohm impedence. Using either A or B, you can use speakers of 4 Ohms impedence.
Dan
Testimonial: "Prompt answering, appreciate it very much."
Multiple speakers in same outlet
Is it ok to hook up two sets of speakers in the same channel? (not sure is "channel" is the correct termanology.) Is there a...
there is no sound coming
there is no sound coming from my speakers. the stereo radio works fine but i can't get sound to the speakers. I have an old fisher...
Aiwa XR-EM50 stereo right channel
Aiwa XR-EM50 stereo right channel dead, both speakers and phone jack. Tested cables and speakers.
what are the specs, especially the wattage to each
what are the specs, especially the wattage to each speaker, on a fisher rs 909 amplifier
Add Your Solution
I have a receiver 'kenwood krf-5030d'..My...
I have a receiver 'kenwood krf-5030d'..My problem is, if i push in the listening mode it only switch to...
When Connecting IPOD via the dock(Denon) i receive...
I have connected my IPOD to the Denon IPOD Dock and the IPDD Dock to the Denon AVR-1911 receiver. The IPOD constanty is...
branchez equaliseur marantz eq 351 sur ampli
branchez eq 351 sur ampli line in out...
Fix-O-Meter
634
634 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Fisher Receiver Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
