Question about Sony Ericsson K610i Cellular Phone
Screen is not clear
My handset was falled over a cup of water. That had got mic and LCD (still not cleared) problemed and I have changed it and its started to workd. It that time I was in UK. Now I am returned to Nepal. But I have changed the USIM but it is not working and should have unlocked. But the technician has told me that can be dead after unlocking but not sure. When I unlock is that happened or not. I mean is it definately dead or not and one more thing does that problem (Screen Not clear) is the problem of the LCD or the main board and what is the parts no. of that (main board) and the actual cost of that also.
Regards
Kumar Adhikari
Kathmandu, Nepal
HI,
Take to Sony serivce center & wait for the response from them.Then it would be clear picture,if it is repairable or you have purchase new one.
Posted on Jan 15, 2008
Dear sir,
as u told that your phone was wet before... Try to disassemble your phone then you need to clean it... Maybe alcohol or a thinner,
Then, you need to dry i first before you assemble it again...
I ever the screen is not clear replace it a new LCD one...
Regarding the network, as what you said your from UK then moved in your place, you also need to unlocked your phone first if they are not the same frequency in Uk..
  • 81 Answers
Hi FRND,
As you told that it is locked so their is no problem for LCD!
Just open the Mobile and dry it ( from Dry cleaner). After this ur loced phone issue...
So you have to unloced the Network code coz wht happen as you told that you are in UK when you last use the phone so UK code for Network is diffetent form Nepal...
Go to service repairer and unloced the Phone ...
Enjoy....
Posted on Jan 14, 2008
  • 3 Answers
The only solution i can advice to you is to change your phone, cause after it seems that the mainboard of your phone is damaged and repair cost may be equal to the price of new phone
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
Today,my keurig started to short cup me, and shortly after that, it will not brew anymore! I noiced while de scaling today( recommended per keurig), that more water is pouring into the water resivor, vs...
The water pump is probably starving for water:1. Remove the clear plastic reservoir and set it aside. 2. Look into the hole that the reservoir sits on. You will see a fine plastic screen that keeps debris from getting to the pump. 3. Clean off the screen. You may have to disassemble the bottom of the machine and remove it to do it right. 4. Put everything back together and the short-cup problem will be history.
Nov 08, 2010 | Keurig Platinum B70 Coffee Maker
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Monitor color is purple?
Most likely, the plug. The pins are known to have a tendency towards falling off, therefore some of the colors are not viewable any more. As a final answer, yes, you should change the cable.
Feb 22, 2010 | Compaq TFT5010R 15" LCD Monitor
Brewer pushing water back into reservoir, not brewing... any suggestions? De-scaled last week (used all week with no problem). Cleaned needle today, no change.
I had the same problem, contacted Keurig and they suggested the descale procedure, which did not work. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, let sit 2 hours and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since.
Jul 12, 2009 | Keurig B70 Coffee Maker
My brewer will not let me change the brew size.
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cup mixture, and when the reservoir emptied of the mix I unplugged it and let it sit 2 hours with the mix in it and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since.
Jun 10, 2009 | Keurig B70 Coffee Maker
"ventilate" appears on the screen
Press the hot water button on the left and leave it on for a couple of seconds - up to 30 seconds. It is because air has entered the system when changing water...worked for me.
Jan 05, 2009 | Saeco Royal Professional Espresso Machine
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Sony Ericsson K610i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
