Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Xerox PE16 Workcenter
Getting a streak of blank running in the middle of the printed copy, although changed ink drum.
Also the phone attached to the same line as PE16, used it before no problems , now when i try to place a call thru the phone on the same line, the PE16 starts the fax and i hear the fax tones on the line so cannot make a call, and on the PE16 it says recieving fax ???
Please advise me, thanks a million
  • Anonymous Feb 12, 2008
    PE16 SCANNING SOFTWARE NOT WORKING
  • 29 Answers
Try cleaning out the scanner
Posted on Jan 16, 2008
  • 233 Answers
If you print from a printer do you get the blank like?
if Yes, then you may have some dead LED's on the scanner (this will need replacement)
if No, then look at your scanner (small thin glass strip that reads the paper when being copied) and clean it. 9 times out of 10 there is some white-out or toner stuck to it, clean it and that should fix that.
hope this helps with the white line
thanks for rating
Posted on Jan 14, 2008
6ya staff
SOURCE:
How do i get rid of streaks on copy. There are 3 black streaks on each copy. I have a xerox 420dc
Print heads need deep cleaning. If not ink jet, then the drum is damaged (scratched) and needs to be replaced to eliminate the bogus lines.
Jan 17, 2017 | Xerox Document Centre 420 DC Laser Printer
Laser printer prints streeks in magenta
swap the A2 and A3 drum.
Send a new color print
If streaks become blue, than you have to replace the drum in the A2 position.
Apr 11, 2013 | Xerox Office Equipment & Supplies
Which cartridge is used in workcenter pe16e
Hello
Xerox 113R00667 Genuine Xerox Toner Cartridge for Workcenter PE16E
You can get more information from here
http://www.tonercartridgedepot.com/xerox-workcentre-pe16-5759-d.html
Good Luck, and do rate the solution if got help
Dec 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Windows vista cannot connect to xerox workcenter pe16 networking printer, error not enough memory
not surprised..vista is a nasty program. not enought memory refers to vista not your PE16
try downloading from xerox website..website is useless but try
Nov 17, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Dark streaks on copies from Xerox XC356 copier. Streaks were light at first; changed to a new toner cartridge and streaks are same size/same place on the page -- but now darker. There are three streaks,...
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Mar 04, 2009 | Xerox XC356 Copier
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
367 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
