Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
I tried to use the LaCie d2 Quadra as a sort of 'jump drive' between my friend's Mac and my PC. Nada, zip, bupkis... The "Safely Remove Hardware" window sees it there but that's all. Can't access it to transfer files and I certainly don't want to mess it up so it won't work on my friend's MAC.
Advice?
Thanks!
  • Anonymous Sep 27, 2008
    how do you format the drive??
  • Anonymous Feb 05, 2009
    same problem
  • 86 Answers
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Posted on Jan 13, 2008
6ya staff
SOURCE:
My Macbook Pro running Mountain Lion does not recognise My Lacie D2 Quadra V2 (301442a) after upgrade from Snow leopard
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Dec 02, 2017 | Computers & Internet
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
How can I format an external lacie drive to mount on both a PC and a MAC without partitioning
You can not use the drive on both systems. It has to be formatted for one or the other. To transfer your files, I would either backup your files to CD's/DVD's or try to network your Mac and PC, then just dump your files to a share folder of some sort.
Jan 09, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I need to be able to use this hard drive on my pc
DataViz makes a product called MacDrive7 that can be installed on a Windows PC that will enable it to use pretty much any kind of device that has been formatted for a Mac. The other option would be to format the drive for a PC since a Mac can utilize PC formatted disks, but you will lose options like forks, etc that are Mac-specific.
Jun 01, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie d2 quadra 500 not showing up on desktop
Try to reformat your Lacie External Drive in Disk Utility.
Dec 07, 2008 | Computers & Internet
Drive not showing up on my desktop
i'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Sep 21, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Help please -LaCie D2 Quadra
Take a look at this link and see if it helps -
http://homepage.ntlworld.com/allcam/pc2mac.html
Jan 07, 2008 | LaCie D2 Extreme 300 GB Hard Drive
Installed on MAC, then Plugged it to PC, now MAC won't recognize Drive
look into Disk Warrior...its a hundred bucks, but it is a miracle worker of sorts and might fix everything for you.
the frustrating thing about DW besides its $100, is it takes less than a minute to fix problems I would fret over for weeks
Dec 29, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
1,544 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
