Question about Acer Aspire 3680 Laptop
No power to notebook
the problem i have is that with or without the main power cord pluged in ......nothing happens when I push the power lights ..nothing...the computer is less than 12 mths old .
  • 77 Answers
It is possible there is a problem with the power pack. Unplug it from the mains, wait for 5 minutes and then try again.
Also try taking the battery out and the power cable and then pressing the power button, as this resets the power management unit in some laptops.
Also with the battery still out, try running just off the mains power.
Failing all of that, take it back under warranty.
Posted on Jan 13, 2008
My Dell CPi D266XT will not power up. The light on the power cord is flashing green. When I push the power button nothing happens. None of the lights flicker like it's even trying to come on.
It is possible that the other end of your power adaptor is defective or just loose. Tighten it securely and try to test if it is emitting voltages by using a multi-tester.
It can also be that there is a problem with the connection form your power adaptor going to the main board of your laptop.
This is a very technical problem so I suggest you let a laptop technician look at it.
Hope it helps.
Feb 04, 2011 | Dell Latitude CPI-D Notebook
I pluged in the power supply and nothing is happening. The small yellow batery icon came on near the screen and nothing else is happening
Remove the mains power lead and then take out the battery. Hold down the on/off button for 30 seconds to dispel any residual power.
Plug in just the mains lead (AC adapter) and see if the machine will boot on mains power only. If it does let it boot up and then shut it down again. Remove AC and reinsert the battery, plug in AC power again and see if it will boot with the battery in.
If it boots up the problem is sorted, if not then there is a problem with battery so you would have to use it on AC only until you find a replacement battery.
Please post back if need anymore help.
Good luck and regards.
Jan 11, 2010 | Dell Latitude D505 Notebook
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
Won't Power up. Plug in power cord and when you
i can't to the internet with the wire only wireless what is the problems
Oct 14, 2009 | Toshiba Satellite 2455-S305 Notebook
I cannot turn on my AV 2260 EY1. Nothing happens.
More than likely the power supply has gone bad. If you or a friend has a Volt meter you could test to see if electricity is getting from the wall to end of the cord (USE CAUTION TO NOT ZAP YOURSELF). In general the first thing to stop working on a laptop is the battery, and the second the power supply cord. That is my guess. How do you fix the power supply cord... buy a new one. I tried to fix one once, ended up all bad.
Jan 19, 2018 | Averatec 2260-EY1 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
My computer wont come on
If the power indicator works when the power cord is pluged in you might call toshiba then...if nothing happens, however, a power unit brake-down does happens from time to time...
May 13, 2008 | Toshiba Satellite A135-S2386 Notebook
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Acer aspire 3500 wont hold charge or turn on
remove the battery and see it the power comes on, if so bad battery, check the connector where the power plugs into the laptop, sometime this breaks or has a cold solder joint, you can test this by wiggling and looking to see if the power lights up. last and worst case is a bad main board.
Jan 07, 2008 | Acer Aspire 3100-1405 Notebook
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
Acer Aspire 3680 Laptop Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
