Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Wireless adapter disconnecting and reconnecting
Whenever I plug in my wireless adapter, it connects to our router for about a second with green signal, and then loses connection. This repeats as long asthe computer is on, with the adapter disconnecting and reconnecting.
  • themoose Jan 16, 2008
    Thanks! Problem fixed.
    Genius:
  • 1,601 Answers
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network ConnectionWireless adapter disconnecting and reconnecting - 1.gif Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Are you using the VISTA adapter driver on the disconnecting computer?
Posted on Jan 14, 2008
6ya staff
SOURCE:
My filemate wireless adaptor keeps disconnecting from the router
Try these:
  • Open Device Manager, open the Network Adapters, double-click the wireless adapter to open its Properties, click the Power Management tab, and deselect "Allow the computer to turn off this device to save power".
  • Some internal wireless adapters will have conflicts with your sound card, using the same interrupt. If either of the devices will let you change the interrupt under Properties, Resources, that would be a good think to test. USB wireless dongles are cheap, and there are no interrupt problems.
Dec 11, 2011 | Wintec Industries FILEMATE 300M 80211N PCI...
Recently bought the Belkin Play max router F7D4302 & wireless play adapter F7D4301. I'm having intermitten wireless disconnection. Everytime when the wireless adapter disconnect after every...
You may need to update your adapter drivers> Here is a site for Belkin and your adapter:
http://en-us-support.belkin.com/app/answers/detail/a_id/3748/~/f7d4101-play-wireless-usb-adapter---drivers-%26-software
Mar 18, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
I'm having an issue with my DI-514 wireless router. I can connect fine when the router first boots up. My laptop will stay connected to the router all day. The problem happens when I disconnect from the...
Open Device Manager. In the Device Manager window, click the plus (+ ) sign next to Network adapters to expand the selection. Under Network adapters , click to select the appropriate wireless LAN adapter. On the menu bar, click Action and then click Properties . In the Properties window, click the Power Management tab. On the Power Management tab, click to uncheck the box next to Allow the computer to turn off this device to save power . Some WLAN adapters have another power saving setting in addition to the one on the Power Management tab. Click the Advanced tab and try to locate a power saving setting. If it exists, disabled it. Click the OK button.
Aug 06, 2010 | D-Link DI 514 Wireless Router (DI-514)
Issue with HIRO H50069 running on XP 32-bit. Network card keeps randomly disconnecting and reconnecting to wireless networks.
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Hiro (H50069) Wireless Adapter
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
moz-screenshot.pnghttp://www.ikarmatech.com
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Windows Vista and Dell Wireless 2350
Try updating the driver for your wireless adapter.
Jan 22, 2008 | Dell Wireless 2350 Router
Wireless router disconnects every 5 minutes...
I had the same problem with my dlink (not wireless). Try going to their website and configure the router. It worked to me.
Dec 07, 2007 | Linksys Wireless-G WRT54G Router
Internet connection keeps dropping
Two possible reasons
If you have hidden your network name (SSID) in the wireless configuration in the router and use WEP or WPA security there may be a bug that can result in extended disconnect periods. Recommended solution unhide the SSID and keep the WEP or WPA security.
Second there are numerous wireless devices in use. Keep your wireless phone base station away from your wireless router. Try changing the channel your router's radio uses to transmit -- Channels 1, 6 and 11 are preferred. Try one you are not using, if that does not work try the other. (If you can see the surrounding channels in you connection wizard you may want to start with one no one else is using)
Dec 01, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
Open Questions:
See all NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, Questions
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
452 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
