Question about Hampton Bay 46056 Callaway II Ceiling Fan
The lights on the ceiling fan dim and brighten at the same time
The lights of ceiling fan dim, as if one bulb is turning on and off after certain period of time. Does this have anything to do with my remote? If yes, what? and if now, is there a solution to avoid this problem.
    Problem Solver:
  • 14 Answers
Yes change your remote
Posted on Jan 18, 2008
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
The ceiling fan works but the light (new bulb) is extremely dim. What could be causing the problem. The fixture was professionally installed and the light was previously bright.
1. Check the wattage of the bulb. you may have fitted a higher, dense filament bulb.
2. The Switch - if you have a dial type knob on the switch, turn that higher to see if the light brightens.
Nov 09, 2015 | Casa Vieja Contemporary 44" Trifecta...
Light on ceiling fan is very dim. Do not have dimmer switch. Changed bulb but light is still dim. Could something be wrong with the fan?
If it has a remote, press down on the light button and keep it pressed down until your light gets to full brightness.
Apr 25, 2015 | Minka Aire Ceiling Fan
I have a hunter ceiling fan model 23898 which has a dimmer switch built in one day a light bulb blew out on it and now we cannot turn off the lights with the switch the only way is to loosen the bulbs in...
Has anyone found a solution for this problem? I have tried a bulb in each light socket and attempted to use the pull/dimmer switch that is on the fan itself. The lights no longer dim nor turn off. I have unscrewed all of the bulbs and tried each bulb in each socket one at a time and still nothing. I have also taken the pull switch out of a different hunter fan to put into this one, hoping that atleast the lights would turn on and off. Still the lights won't turn off using the pull switch. I am out of ideas.
Sep 11, 2011 | Hunter Ceiling Fans Individual...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Lights are now dim.......
Aside from a wiring fault upon installation that may be creating a small short, or interference from the fan motor, have you tried fixing the cheap parts? I.E. changing the lightbulbs out for a different set, or different types? Try using flourescent bulbs in place of your normal incandescent bulbs. Also, what wattage are you using? Your fan unit may have a limitation on wattage, or may only be throughputting a certain wattage due to a wiring problem. Does your fan have an energy saver setting?
Aug 19, 2006 | Hampton Bay B52852WPB Redington III White...
Hampton Bay 46056 Callaway II Ceiling Fan Logo
199 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
