Media test fail
I have a HCL notebook. New one. Recently i has started to give some Media test fail error and does not detct the hard disk eventually leading to the computer failing to boot. Can u help me fix it?
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    hmmm...sounds oddly like a pre hard drive crash failure mode. Can you advise the model number, please?
  • 108 Answers
It seems that your Hard Disk is about to crash. If it is under warranty go to the authorised srvice center.
Posted on Feb 04, 2008
90B fan error
Start your notebook and start tapping the F2 key. In the diagnostic screen perform the hard disk diagnostic. If the diagnostic reports a hard disk smart test fail, then your hard disk is failing and must be replaced. That is the only way you will be able to return your notebook to useable condition.
If hard disk is ok I suggest you goto HP support Forums at
http://h30434.www3.hp.com/t5/Notebook-Lockups-Freezes-Hangs
Jan 23, 2014 | HEWLETT-PACKARD Pavilion dm4-1265dx...
Operating system not found
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 13, 2013 | IBM ThinkPad T40 2373 Notebook
My hp pavilion dv 9500 notebook pc stops working at once since last two weeks. when I go to bios setup>diagnostics it gives me error 10008 and adds that replace your hard disk. In case that I work on...
for now as a quick solution take it to the service and install a new hard disk, install windows from the recovery disks and get your pc working again. install acronis home 2011 (am using it and its a savior) and backup your system. after doing all that take ur failed hard disk to an expert and try to save ur info.
May 16, 2011 | HP Pavilion DV9500T Notebook
I have a dell vostro 1510 laptop. The windows xp does not load. I run the dignostic CD also. It is showing error 0F00:075D - The self test failed. I also tried to repair XP but it is not detecting the...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 19, 2011 | Dell Vostro 1500 Notebook
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Jul 18, 2009 | Dell Latitude C640 Notebook
My laptop is telling me media test failure. What does this mean? Its an Aspiire One AOA150
The media test failure and a clicking sound from the hard disk indicated that the hard disk has failed. To get the laptop goining again, you need to replace the hard disk and install Windows on the new hard disk.
Jun 05, 2009 | Acer Aspire One PC Notebook
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
When i turn on my notebook it goes to gateway screen. then ate the bottom left it says f2 to bios menu. well any way, on the boot menu it say's media test failure and exiting pxe-mof. under that it says...
ur Hard disk is giving u problem either it is failed or going to failed jus buy a new hard disk whichever suits ur needs i mean , hitachi's are the best i think reliable and fast go and solve
Feb 19, 2009 | Gateway MT6840 Notebook
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
