Question about Toshiba Satellite 1805-S253 Notebook
How to run setup
How to run bios setup
  • 689 Answers
While holding the ESC key, turn the power on.
Do not release this key until a message appears.
Press F1 to enter the System Setup utility
Good Luck
Posted on Jan 13, 2008
  • ghost Oct 30, 2011
    Thanks. than got me back to set up screen and default values. Now boots to windows XP screen then shuts down.
Entering setup network selected as first boot device for current boot
That a LAN boot Rom is used does not affect the keyboard entry used to enter setup.
The BIOS controls if the onboard LAN will run on boot up.
LAN Boot ROMs are used to download operating system code from a network server. So, the BIOS has priority.
The BIOS runs first, and if you enter setup by pushing the proper key for the motherboard, you can change the boot to DVD or another device (USB Stick) to troubleshoot the PC.
Jul 02, 2015 | Computers & Internet
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
How to setup bios when installing windows 7 flash drive?
Hello its not easy to explain in words but here is some videos you can watch:
You will need adobe flash player to watch:
The asus homepage is here:
You will need that for the driver download.
The mainboard does not support Win 7
But you can try the drivers for vista
It sometimes work.
Good luck
Aug 21, 2012 | ASUS P5PE-VM Motherboard
Bios nonva 5600 aspire
The BIOS Setup Utility is a hardware configuration program built into your computer's BIOS (Basic Input/Output System).
Your computer is already properly configured and optimized, and you do not need to run this utility.
However,if you encounter configuration problems, you may need to run Setup.
To activate the BIOS Utility, press
during POST (when "Press <F2> to enter Setup" message is promptedon the bottom of screen).
The setup screen displays BIOS as follows:Navigating the BIOS UtilityDuring setup,all Fn function keys and power saving functions are disabled.
There are five menu options:
Main, Advanced, Security, Boot and Exit.Follow these instructions:
To choose a menu, use the cursor left/right keys (zx).
To choose a parameter, use the cursor up/down keys (wy).
To change the value of a parameter, press p or q
while you are in any of the menu options to go to the Exit menu.
In any menu, you can load default settings by pressing t
You can also press u
to save any changes made and exit the BIOS Setup Utility.
hope this helps
Aug 02, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
Run BIOS configuration...power on...then press the DEL to run BIOS setup configuration...if you cannot access this process. Your Motherboard BIOS IC is defective and need to replace it. But most of this kind of problem...technicians replace the whole MOTHERBOARD with new one.
So, I suggest you to replace the motherboard with new. Do not intent to replace the BIOS IC because it will not work...due to different programming language depending on the brand of BIOS. Because AWARD and PHOENIX has different configuration...
Sep 16, 2011 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
Setup utility
I think you are referring to the BIOS setup. The BIOS is the very first code that is ran after you trigger POWER, and controls all of the hardware in the PC, and without this 64k of code, your computer would not run. No display, no nothing. There have been some viruses known to infect the BIOS, the most famous being CIH, which formats the hard drive, empties the CMOS memory (also part of the BIOS, where settings such as time are stored) and re-flashes the BIOS, rendering the PC unusable. Luckily, this only infects Windows 9x machines with ATX motherboards.
May 05, 2010 | Acer Aspire 4315 Notebook
Invalid configuration information- please run setup program & do not enter setup
1)"F2" on Dell Logo to go to bios screen
load Bios defaults in bios
Save and exit from bios
2)Install BIOS Update from
Nov 22, 2009 | Dell Inspiron 6400 Notebook
Toshiba Satellite 1805-S253 Notebook Logo
119 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
