Question about Philips CD6452B/37 Twin Cordless Phone
Audioline cordless phone
Base station, answering machine, speaker phone working fine.
Handset not connecting to system. Charging light & talk light flashing together. Need insrtuction manual to work through basic trouble shooting.
(instructions packed away somewhere very safe I am told)
  • Anonymous Mar 21, 2014
    where can I buy a replacement aerial
Answering machine not working on the base station
Posted on May 12, 2008
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
I have a three handset 6.0 v tech. the one handset keeps beeping. What is going on?
With vtech phone (many times) a beeping handset indicates a low battery or an inability to connect to base station. check to make sure the battery is connected correctly and that the phone is setting in its docking station correctly. (remover and obstructions that would prevent correct charging) If this fails go to your local store that sells batteries for cordless phones and purchase to correct type.
Oct 13, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Registering a new phone
With a little searching I was not able to confirm this phone could handle more than one cordless handset. Are you replacing a defective handset or trying to add a second. If adding, do you know if it can handle the second unit (is it advertised on the box, in the user guide, etc?) If replacing, you most likely have to de-register the old handset on the base unit before you can register a new one. If you are adding, try de-registering the working handset anyway and registering the new one. If the new one registers and you cannot re-register the once working phone you will know either the system cannot handle two phones or (if the new one will not register but you can again re-register the original) that the new handset has a problem and should be returned.
Jul 10, 2007 | Uniden Cordless Phone
Philips CD6452B/37 Twin Cordless Phone Logo
378 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
