Question about Toshiba Satellite M45-S169 Notebook
Freeze It wil start up ok then stops where it is. Screen stops exactly whre it was. If you apply pressure to left side of mouse pad it will pick up exactly whre it was. A few seconds later it stops. I can actually take out the hard drive and the screen stays. I put the hard drive back on and apply pressure and it picks right up like it never knew the hard drive was gone. I have taken the mother board out and looked very close with magnifying glass to see any crack or anything. I don't understand that if there is a short or something, it should shut computer off or something. If I apply alot of pressure, the computer will run fine. I have heard that it could be a cracked motherboard, but if that is case, shouldn't the system crash?
  • Anonymous May 11, 2008
    I am having the exact same problem, with the exact same solution to pressing on the left side of the mouse pad. Pretty annoying to deal with and no one can figure out whats wrong with it. I'm just going to buy a new computer.
    Genius:
  • 1,003 Answers
I THINK YOUR HARDRIVE IS GOING OUT IS THE HARDDRIVE MAKING CLICKING NOISES When trying to Load.
Replace hardrive and this should fix your problem
Posted on Jan 15, 2008
Unlock mouse intel core 15
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
Click the "Apply" button and then click the "OK" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
Sep 25, 2012 | Intel CTL E09L 2goPC Laptop
How can i activate my mouse sensor???
or
or
hope this helps
Sep 24, 2012 | Acer Aspire 5102WLMi PC Notebook
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
My touchpad has stopped working. Device Manager
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR
one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Comment back with Make and EXACT model
Mar 24, 2010 | Computers & Internet
Toshiba a45-s120 laptop mouse pad is frozen
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
To setup the Internet Connection: To Start, go to the “Control Panel,” you want to open the “Internet Options” window. Click on the “Connections” block, click the “Setup” button, and follow all the instruction carefully. “Important! Always click “apply, ok, and restart the computer after making changes to the computer.”
"Did this solution help?"
Feb 01, 2010 | Toshiba Satellite A45-S120 Notebook
All functions halt unless I press very hard on touch pad area....
Doubt it. Seems like a bad fault, maybe it's worthwhile contacting whoever you bought it off - it sounds like a faulty good.
Jan 25, 2010 | IBM ThinkPad T43 Notebook
T-43 Laptop - Screen freezes, mouse freezes, all functions stop..
The Touchpad is pressure sensitive, you can program the Touchpad's functionality. Go to Control Panel, click, to open Mouse Properties. Click the Device settings (block), select the Settings button; after the Touchpad Wizard appear! "View the (left) "Select an item" pane, and click to start the Touchpad's actions." Follow all the instructions carefully. I hope this Fix it
Jan 21, 2010 | IBM ThinkPad T43 Notebook
Mouse pad button is pushed in
start ------ control panl -------- mouse ----------properites-------Buttons--------- Switch primary and secondary buttons ------------apply----------- ok
Feb 10, 2009 | Acer Aspire 3690-2196 Notebook
Freezes exactly where it is. Apply pressure to palm areas and it continues?
You must have a melted contact. Try to identify in the zone you apply pressure (or in the far angle of the M/B that should rise while you push the mouse pad - tension) and see if there's a "free" contact...Try it opening the cover and letting the pc work...see what the pressure modifies....it's weird though!
Jan 13, 2008 | Toshiba Satellite M45-S169 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Toshiba Satellite M45-S169 Notebook Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
