Question about Toshiba Satellite M45-S169 Notebook
Freezes exactly where it is. Apply pressure to palm areas and it continues?
It wil start up ok then stops where it is. Screen stops exactly whre it was. If you apply pressure to left side of mouse pad it will pick up exactly whre it was. A few seconds later it stops. I can actually take out the hard drive and the screen stays. I put the hard drive back on and apply pressure and it picks right up like it never knew the hard drive was gone. I have taken the mother board out and looked very close with magnifying glass to see any crack or anything. I don't understand that if there is a short or something, it should shut computer off or something. If I apply alot of pressure, the computer will run fine. I have heard that it could be a cracked motherboard, but if that is case, shouldn't the system crash?
  • mgashop Jan 13, 2008
    I lay it flat and when it stops, you can see the hard drive light go off, etc... just freezes in place. If I push stright down with some pressure just to the left of the mouse pad it picks up right where it left off. right under the area where I push is some smaller square processor looking thing and I have looked very closely with strong magnifying glass and it is connected. I have gone over that portion of the motherboard veryclosely and I don't see any solder breaks. I just don't understand. I would even go as far as take a video of what i'm doing and send it via email to someone if they think they can help.
    here is a link showing somewhat same thing they do to work on theirs:
    http://www.asklaptopfreak.com/laptop-not...
You must have a melted contact. Try to identify in the zone you apply pressure (or in the far angle of the M/B that should rise while you push the mouse pad - tension) and see if there's a "free" contact...Try it opening the cover and letting the pc work...see what the pressure modifies....it's weird though!
Posted on Jan 13, 2008
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
My palm treo pro keeps freezing lately, when i would start writing a text and press the space bar in the 3rd time i would punch it, it will completely go to the menu screen and i canoot hear music or go to...
Most likely, a program that you have installed is causing your Palm to freeze up. If you remember installing a program when the freezing started, delete the program and check if it keeps freezing.
Jan 21, 2011 | Palm Treo Pro Smartphone
2005 f250 V10 gas super duty. Cranks but does not start in cold weather. Truck is from warm weather area now in freezing weather for first time. No pressure from fuel pump. Pump changed, same problem.
Ok you have no pressure from fuel pump to the injectors and you replaced the pump. Sounds as if you need to check or replace the relays which send the signal from your ignition switch to your fuel pump to engage/shutoff. Warm weather area sorry doesn't really apply unless you're in an older carburated vehicle
Dec 10, 2010 | 2003 Ford F250 Super Duty Crew Cab
My Dell D630 wireless is not working
Check if your system has a wifi switch and if it's turned on. Press Fn+F3 to enable your wireless inside windows. If you have windows xp, try this...click start, run and type services.msc and press ok. double click wireless Zero configuration from the services window and set it to automatic then click apply then click then start the service. If all else failed, you have to replace your wireless card.
May 24, 2010 | Dell Computers & Internet
All functions halt unless I press very hard on touch pad area....
Doubt it. Seems like a bad fault, maybe it's worthwhile contacting whoever you bought it off - it sounds like a faulty good.
Jan 25, 2010 | IBM ThinkPad T43 Notebook
T-43 Laptop - Screen freezes, mouse freezes, all functions stop..
The Touchpad is pressure sensitive, you can program the Touchpad's functionality. Go to Control Panel, click, to open Mouse Properties. Click the Device settings (block), select the Settings button; after the Touchpad Wizard appear! "View the (left) "Select an item" pane, and click to start the Touchpad's actions." Follow all the instructions carefully. I hope this Fix it
Jan 21, 2010 | IBM ThinkPad T43 Notebook
Start up for only 2 seconds and will automatically shut down
OK SO U HEY IM SERIOUS IT WORKED FOR MULTIPLE PEOPLE IT WORKED FOR ME IF IT DIDNT WORK I WOULDN'T BE TELLING U NOW.
STEPS
- USE YOU STRONGEST ARM AND USE UR PALM
-APPLY ALOT OF PRESSURE WITH UR PALM AND PUT THE PRESSURE ON THE ENTER BUTTON.
-WITH THE PRESSURE ON THE ENTER BUTTON ANYWHERE AROUND THE ENTER BUTTON AND TURN IN ON.
- IF IT DIDN'T WORK THE FIRST TIME APPLY MORE PRESSURE BECAUSE THE NVDIA CHIP IS NOT CONNECTING TO THE MAIN BOARD SO ADD PRESSURE AND TURN IT ON.
-NOW RUN UR TX1000 FOR A WHILE TILL IT GETS WARM SO THE NVDIA CHHIP CAN ATTACH TO THE BOARD AND UR DONE!
TELL EVERYONE WHO HAS THIS PROBLEM 100% GUARENTEED TO WORK YO!!
Oct 01, 2009 | HP Pavilion tx1000z Notebook
Hpqste08.exe and hpqdstcp errors
try this click on the start button then type on the start search engine "msconfig" hit enter then click continue then click on the "startup bar" then click the disable all remember click the startup bar only ok then apply then ok
Apr 11, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Freeze
I THINK YOUR HARDRIVE IS GOING OUT IS THE HARDDRIVE MAKING CLICKING NOISES When trying to Load.
Replace hardrive and this should fix your problem
Jan 13, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite M45-S169 Notebook Logo
105 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
