Mitsubishi WD-65735 Television Logo
Posted on Nov 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced bulb and the tv worked great. I turned tv off and could not get a picture. tv blinks red light on lamp.
  • grob0104 Nov 23, 2009
    it does not blink red . It stays red on the lamp light indicator
Anonymous
Level 3:
  • Master 541 Answers
  • Posted on Nov 23, 2009
Anonymous
Master
Level 3:
Answers
541
Questions
Helped
126487
Points
1217
If it is a continuous blink you have a DM module problem. There are 4 capacitors that need to be replaced. This can be a very complicated repair. Have a Mitsubishi authorized repair shop check it for you. Thanks for using fixya.
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
2answers
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
6helpful
2answers
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
3helpful
2answers
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
5helpful
2answers
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
1helpful
No picture
ballast is not striking the lamp and needs replacing
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
