Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 My printer use to pull the paper down nto the right side of the printer and cause paper jam. Now it will not print without a paper jam. I can't get it to even feed the paper without a problem. I'm concerned that school will start soon and I will not be able to print my assignments. Please help me audreydiane@msn.com
DRIVER
Posted on Jan 14, 2008
Lexmark X1270 won't grab on right when I try to print
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 18, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark x1270 keeps jamming not grabbing on the right side.
Hey the printer keeps picking up all the paper in the tray and sliding it through without printing. what is causing this problem? if i put 1 sheet it still slides through without printing. Printer X1270...
It could be the cartridges in the printer. Remove the sheets of paper from the feeder. Remove the cartridges from the printer. Close the cover then unplug/re-plug the printer into the power source to reset it.
Wipe the cartridge nozzles using a slightly moistened soft cloth to clean it from clogs and dirts.
When the printer turns on, reinsert the cartridges and make sure they are secured in the carrier. Load some paper and try to print again.
Aug 10, 2011 | Lexmark X1270 All-In-One InkJet Printer
Paper Jam
It sounds like during one of these jams, a piece of paper was probably left over in there and maybe stuck "out of sight" in the paper path causing the paper to pulled to one side.  Look closely, my guess is that it is only a small corner of a page that is stuck in the path.
Mar 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark x1270 paper jam
hah - I had this problem on my old 1270 - there is a jam - its just very small - mine was caused by half a peanut lodged under a pickup roller - take the back paper guide off and check carefully - it might just be a piece of grit - the paper will skew away from the point of the jam so see where it skews and check around there
hope this helps, cheers
Dec 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 3400 series paper jam
hmmm...well.that suggests that you have something along the left side
open up top and back, and inspect for any paper fragments
Aug 19, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270 - flashing light.
sounds like the paper jam might have stripped some teeth off the gears in the printer or the motor might have failed have a visual look at the gears that pull the paper through if broke measure it and tell me how many teeth it has i might have one, or even the motor i have extra printers lexmarks for parts.
Dec 08, 2007 | Lexmark X1270 All-In-One InkJet Printer
I cant instoll my lexmark 510 series in my computer
what problems are you having specifically?
Do you have a CD ROM for the printer?
Oct 29, 2007 | Computers & Internet
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
132 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
