Question about Whirlpool GHW9100L Front Load Washer
Washer wont start
Whirlpool -ghw9100lw1 wont start sicle
  • crowhill Feb 06, 2008
    the green push to start button at first it would not push in ...I tried cancel hit it twice and restarted still could not get the button to push in and no click to indicate start... checked the door to be certain it was locked...finally pushed in on the button very hard and held it for a second and it finally started..but It takes some mightyhard pushing to get it to click and start. Do I need to find someone to have it repaired??
  • 1,554 Answers
See this link to test it for issue
Posted on Feb 02, 2008
GHW9100LW1 F-11 code right afer it starts
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control panel on my Whirlpool Duet model # GHW9100LW1 reads control locked. How do I get out of this?
There is a control lock so noone can start the washer washer or change your settings after starting the washer. There is a subscript under one of the option buttons that says (usually not very dark or prominant) Control Lock Hold for 3 seconds. Hold this button in for 3 seconds, sometimes slightly longer and the control lock should turn off. Most are not aware of this feature because it is never used. If this does not solve your problem unplug the washer for about five minutes and try again, if problem still persists please repost.
Thank you
Please rate this post
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool GHW9100LW1 washer stopped working
be sure that the tub is moving around with out the outer tub moving....could be a motor controller problem.....but heres the part#s tub assembly#8181912 youll want to replace the seal too. seal#8181673
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer model GHW9100LW1 will nopt fill or start
Could be one or more of the following items not working properly or bad:
- Flowmeter.
- Water inlet valve
- Water pressure switch. (last thing to replace)
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Apr 07, 2009 | Whirlpool GHW9100L Front Load Washer
defective timmer, defective water level pressure switch open circuit
Oct 08, 2008 | Washing Machines
Door will not shut
if the stike on the door is not broken then it is the door latch
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Try holding the End of Cycle Signal button for about 3 seconds and see what happens. Mine started working again.
Ok Yankee
Nov 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
192 people viewed this question
Dan Webster
Dan Webster
Sal De
