Question about Canon ZR100 Mini DV Digital Camcorder
Canon camocorder thick gray lines on ever recording
My camcorder has thick grey horizontal lines across the screen when i record and whenit plays back. i bought a head cleaner tape for it but it's still there what do i do? I have only used this camera maybe 10 times.
  • 3 more comments
  • Anonymous Feb 11, 2008
    We have a canon camcorder NTSC ZR 200 and we also have thick grey horizontal lines on recording and playback. We've tried using new tapes and re-winding to no avail. Any advice on how to rectify the problem?
  • tetecarree Mar 26, 2008
    Same here. Left it sitting for a few months, went to use it and everything has grey stripes across it (not in the viewer when recording, but definitely there during playback) - even stuff that didn't have it before. Transferred video to my computer and the stripes were transferred, too.
  • Anonymous Mar 27, 2008
    Same here. I just pulled out my camcorder (last use Aug 07) and all tapes have thick grey lines!!! HELP!!!!!!!!
  • Winston1 Apr 26, 2008
    Same exact problem.  Screen is clear until you play back recording - then gray lines appear.  Any more suggestions?
  • bryanlh Sep 24, 2008
    grey lines during play back. can zoom in and out to make the grey lines bigger and smaller but a cleaning tape blown air nothings helping don't think I should have to pay $157 dollars, what they want to fix this. there
    are horizonal grey lines.
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Posted on Jul 19, 2009
  • SimpleDimple Mar 27, 2011
    You are a lifesaver! This worked for me.. I have had my camcorder for years and now it does this. But your solution is what worked for me. THank you for sharing!
  • andy Dec 04, 2011
    it worked for me too, thanks very much. I hadn't played back anything since I bought the camcorder, now I've been able to transfer it all to a laptop without grey stripes.
I had exactly the same problem. Recent recording. Tried to play back a week later, and solid grey horizontal lines symmetrically spaced and intermittent distorted audio. This has to be a tape head alignment / read error.
What did not work:
1) taking battery in and out
2) winding tape backwards and forwards x2.
3) fast forward in play
4) taking in out x6
5) playing around with camera settings such as 12 /16 bit audio.
What did work:
Putting in brand new tape and recording a few minutes. Play back of this tape worked fine. Subsequently trying the old tape worked fine to.
Posted on Jul 25, 2010
  • mwggwm Dec 30, 2010
    This did in fact work I only had to go through step 2 though. I had to go to this fix as a result of having performed another set of steps for my intial problem the fact that the tape would only load into the yoke mechnism but not stay in the camera long enough to engage and close the door. That probelm was amazingly fixed by using the tap method found also on this same site. The fix for this problem unfortunately discovered Christmas morning and the fix was to place the camaa LCD screenside down in your palm and tapping the opposite side 3 times.
    Rube Goldberg would be proud of you problem solvers. These fixes are so ridulous on first glance that you'd swear they could never have possibly worked but they did both times.... Just imagine what we all dd before the internet..... Pay Canon dollars
Ok, I've figured my one out. Funny thing was, a cleaning tape didn't help at all, but when I took the battery out (to save frying the camera) and sprayed electronic component cleaner directly into the area where the tape goes and let it dry, the camera worked properly after.
Posted on Apr 06, 2008
  • 4 Answers
You could check the settings to see if you have accidentally changed something.
Posted on Mar 03, 2008
    New Friend:
    Problem Solver:
  • 10 Answers
My cannon miniDV also shows gray lines. When i would put a cassette in the camcorder sometimes it wouldn't let me do anything and would say eject disk. I looked on YouTube and saw how to clean the head with alcohol and a q-tip then let it dry for about 10 min. My head was filthy so it needed it but gray lines remain. I was also told that I may need to demagnetize my head so I bought a demagnetizer to try it out from eBay. Just Plugged it in and placed it on the head for 1 sec no success, i tried it again for 10sec according to another post, no success. I finally found another solution to try. I just forwarded to the end of the cassette where I had nothing recorded, I left the camera lens on and recorded for about 7 min. Guess what, it worked! I thought I was going to have to throw this camera away but nope! I suggest keep trying and one of these options should fix it! Cleaning the head may have fixed the eject disk but the recording with the lens on and in a quiet room fixed the gray lines!
Posted on Mar 04, 2013
Sometimes just taking the battery out and put it back works like a charm.
Posted on Aug 02, 2008
Has anyone else tried tetecarree's solution? I'm hesitant to spray anything into my camera.
Tetecarree, can you tell us the brand name for the cleaner?
Posted on May 17, 2008
Has anyone else tried tetecarree's solution? I also have the same problem but I'm hesitant to spray anything into the camera.
Tetecarree, can you give a brand name for the electronic component cleaner?
I sprayed out my camera but the grey lines remain. Is there something else I can try other than taking it to a shop? I hesitate to pay 1/2 the price of a new camera...
Posted on Sep 06, 2008
  • 3 Answers
Have you tried running a cleaning tape through the camera?
SOURCE:
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
Jan 12, 2008 | Canon ZR200 Mini DV Digital Camcorder
On playback, the video has gray lines across it
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Pink or grey horizontal lines on video download or viewing
I have the same issue and have for over a year (haven't had the time to send it to Canon for a few weeks to analyze, but have cleaned it numerous times). But I can tell you that the problem is internittent and the recordings are fine. Eventually, don't know the remedy, but it will suddenly stop doing that and I can download fine, and watch on camera fine. When it does happen, I just keep recording. It never shows up permanently. I re-tyr downloading or viewing and about the 3rd or 3th time (let it sit for a few hours between) it is normal!
Oct 09, 2007 | Canon ZR90 Mini DV Digital Camcorder
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Lines like strips horizontally across the LCD !!!!!
I had same problem. Don't buy a cleaner. Look inside camcorder and make sure both reel turners are equal in height...they can slide down. Turn both of them...one of mine was down and also did not turn to make contact with tape. We got it to turn and the message C31:23 and the dinging quit. Camera instantly worked like it used to. Good luck.
Dec 01, 2006 | Sony Handycam DCR-TRV30E Mini DV Digital...
Canon ZR100 Mini DV Digital Camcorder Logo
3,084 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
