Question about Mitsubishi ColorView XL25U Multimedia Projector
COMPONENT OUTPUTS MY COMPONENT VIDEO OUTPUTS DONT WORK
  • 3 more comments
  • JOBRON Jan 13, 2008
    thanks for the reply , its not the monitor out terminal but the bnc outputs r , b , g , .... i will try what you suggested and see what happens ,,, thanks again
  • JOBRON Jan 14, 2008
    yes those are it , i'm trying to use the first three r/pr,g/y,b/pb    but they dont work for some reason .
  • JOBRON Jan 15, 2008
    thats the problem , i cant get to the signal menu to switch to rgb while signal  source is switched to computer .. out of the four menu options i can only toggel thru two of them ,
    whats a hard reset , i did press the tiny little reset button
    one thing , im not using it with a pc , its part of my home theater system . i wanna use the component hook up for the hd quality of the picture
    Brigadier General:
  • 6,966 Answers
I'm assuming that you are referring to the "MONITOR OUT terminal (D-SUB mini 15P)" at the back of your Mitsubishi XL25.
If yes, the only instance that there will nothing shown at the external computer/VGA monitor would be when the SCART is set to ON. Likewise normal computer video signals are not projected.
Normally, SCART should be set to OFF except when used with some European devices. You can enable/disable SCART under the Menu/Feature.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
  • 3 more comments
  • Louie  Role
    Louie Role Jan 14, 2008
    Hi again,
    The 5 BNC connectors marked R/PR, G/Y, B/PB, H/HV and V are all inputs.
    Hope this be of further information.
    Cheers.
  • Louie  Role
    Hi again,
    Cheers.
  • Louie  Role
    Louie Role Jan 15, 2008
    and Hello again,
    There are only 2 ways the R/PR, G/Y, B/PB, H/HV and V as inputs will work:
    1. Your video source is designed to give outputs 3-line fitting (Y, CB, CR); or
    2. Your video source has an HDTV decoder with BNC outputs or uses an adapter/splitter (Mini D-SUB 15pin to BNC). If you are using a computer's VGA output as the video source, you would also need to install on the PC DDC driver aside from the adapter/splitter. In most cases, you need to power up the projector first before booting the PC. Some Mac units require a MAC adapter, some devices (video source) are not compatible. Your screen resolution should be 1024 X 768.
    Either way, your projector must be set/enabled to view video source "Computer/Component Video IN 2" or the Computer IN Signal Menu to RGB, either by the remote or on the control panel. Both will not work if the Menu is displayed.
    In some instances, some devices are just not compatible through this connection method.
  • Louie  Role
    Copy, have you done a hard reset?
  • Louie  Role
    Yup. that's the small button at the rear. Additionally, there is also a soft reset in the Menu/Feature, RESET ALL/OK
    Have you tried, powering the projector with the PC off, and selecting in the signal menu "RGB" (not the AUTO or the other way around), pls try with the SCART in OFF (then ON which ever works), then power on your PC. If you are using a laptop, there's a command sequence to activate the external VGA display aside from the LCD, its Fn + F? key (depending on the brand/model of your laptop).
    Incidentally, may I ask why not simply VGA to VGA (Mini D-SUB 15pin to Computer/Component Video IN 1?
    Pls post back your PC's brand/model as well as how it is hooked up to the projector (adapter/splitter).
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
No component video output.
Check that the input video mode for s-video inputs is AUTO or S-VIDEO.
setup>manual setup>input setup>input video mode.
Jul 20, 2009 | Denon AVR-2105 Receiver
Even though my dvd and receiver have component video inputs/outputs, when i hook them up i don't get any picture. i have connected the audio with a digital coax and that works fine. why doesn't it work?
Have you enabled the component output on the dvd player and/or switched the output to "component out"? This type of connection doesn't have automatic recognition like scart.
Jul 18, 2009 | Yamaha RX-V620 Receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
1st time using component video connections on my onkyo
Yes, switch to the video input that you are trying to configure (i.e. video 1-4). Press the menu button on the receiver or the remote and cycle to video settings. There should be a setting that says "video output" or "output" - set that to component. You may also have to configure the Input for that particular setting. For instance, if you have an HD tivo going into component 2 but you want it to be Video 1. Select Video 1, hit the menu button and scroll to video setup. Select video input setup and cycle it to component 2. Next, use the menu to cycle to video setup, select video output, switch to component. This should solve your problem. As a sidenote, you may also have to configure the audio in/out if you're using digital coax or optical. Let me know if this works.
Feb 02, 2008 | Onkyo TX-DS787 Receiver
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Jan 23, 2008 | Yamaha HTR-6030 Receiver
OUTPUTS DONT WORK?
hook it back up to the HDTV and get into the menus. Get into the video menu and make sure that it is NOT set for progressive scan (normal TV's are Interlace).
Sep 12, 2007 | Sony Playstation 3 (PS3) Console
Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Nov 26, 2006 | GoVideo DVR4000 DVD Player/VCR
Mitsubishi ColorView XL25U Multimedia Projector Logo
144 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
