Question about Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
How to replace water filter
Can not locate the filter for replacement.  Where is it located?
    Scholar:
  • 90 Answers
If it is only a few years old it is on the bottom of the unit. There will be a pull lever. When in doubt go to sears.com and enter your model number. There is a link to show you where it is..
Posted on Jan 28, 2008
Where is water filter located on kenmore coldspot model #52212100
contact sears parts to get a owner manual but filters are usually locate in line before the unit.
www.searspartsdirect.com
Sep 14, 2014 | Kenmore Refrigerators
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
How to locate and replace internal filter?? For frigidaire
Good Afternoon Friend,
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
May 30, 2014 | Frigidaire Dehumidifiers
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Jun 12, 2011 | Maytag MFF2557HES Stainless Steel French...
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water dispenser
My filter is located on the inside of the refrigerator in the top right corner. It twists off and is easy to replace.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I CANNOT REMOVE THE WATER FILTER LOCATED IN THE UPPER RIGHT INSIDE THE REFRIGERATOR. I TRIED TO TURN IT COUNTER CLOCKWISE BUT IT WILL NOT COME OUT. THE PART NUMBER ON THE FILTER IS UKF8001. ANY...
  1. 1. Look for the water filter cartridge. On some refrigerators it is located in the back, upper right corner of the refrigerator compartment. Some refrigerators have it in a tubular-like slot under the door and accessible from outside.
    2. Remove the old cartridge. On the cartridges that are located inside the refrigerator, the cartridge should be slowly turned to the left. Don't pull down on the cartridge. A small amount of water may drip. On the type that are under the door, follow the arrow labeling for the direction to unscrew it. Slide it outside.
    3. To replace a filter, fill the replacement cartridge with water from the tap. This will speed up water flow after installation. Run water from the dispenser for three minutes after replacing a filter to clear the line. Refrigerators with a filter warning light require you to reset the light. Press and hold the Reset Water Filter button to do that.
Jan 18, 2010 | Refrigerators
Replace water filter
HI. Frist, make sure that your unit is equipped with this feature. if you have varifyed that your unit is equipped with a filter fo this nature, the location will be on teh front, lower grille area. This is the most common location for a water filter. Simply kneel down, and look at the bottom section of your unit, on the front. There is a grill, with a circular cut-out. This will be where the filter is housed. You will need to turn the handle counter-clockwise to release.
Now, in newer units, the filter will be located inside the refrigerator compartment, just above the top shelf, in the right, or left corner. if both locations do not show a filter, check the backside of the unit for a 8 inch cylindrical device.
Nov 19, 2009 | Whirlpool Refrigerators
Where is the water filter located on a kitchenaid ksrp25qdwh00
This particular water filter is known as a ``in line water filter`` and is located at the BOTTOM of the fridge at the LEFT hand side. located in the grill at the bottom. first you must remove the filter cap and then It simply twists out for easy replacement. part number for the water filter is 2255519. and should be replaced based on a 6 month period or the amount of water filtered. hope this helps
Thanks
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Where is the water filter located on the Samsung SRS2028CSS
The water filter is located in the
upper right-hand corner of the fresh
food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from end
of filter and insert into filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Sep 10, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
