Question about Panasonic PT-AE700U Multimedia Projector
Projector panasonic projector will not power up.
Other than the usual stuff (power cord etc.), check that the lamp cover (not the lens cover) is securely covered. There's a safety mechanism preventing projectors from powering up if it isn't.
Posted on Jan 13, 2008
I had this problem and pressed the power and enter buttons at the same time and it powered up
Posted on Jan 14, 2008
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
Unit powers up then shuts off after a few seconds
The problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a powericon1.png supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so, you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Apr 07, 2013 | Sanyo PLC XP30 Multimedia Projector
How to reset the panasonic PT-L702ES LCD PROJECTOR after changing it bulb ET-LA702
How to reset timer on PT-L702E LCD PROJECTOR:1. Power on the projector and go into the menu
3. Press and Hold ENTER for at least 2sec - message will change to something like 'Power Off to reset timer'
4. Press POWER to power off projector
5. Power projector back on
The timer has now been reset to Zero Hours
Sep 21, 2011 | Teac Panasonic Etla702 Replacement Bulb (...
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Menu -> Option 2 -> Lamp Timer -> hold enter 3 seconds -> power off
Jun 24, 2009 | Panasonic PT-LB50SU 2000 Lumen SVGA...
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
242 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
