Question about Matsonic MS9087C Motherboard
No Power onle fans had power and there was 1 beep. I reseated the DIMMS and now there is no power at all. Do you think this is a memory, CPU, Power Supply or motherboard problem?
    President:
  • 2,351 Answers
Memory.
Suggest you cut down on the memory to using one DIMM.
Try your dimm down through the slots, one slot at a time. If still trouble, switch dimm and do the same. One beep is a memory issue.
Posted on Jan 13, 2008
My laptop dell 3541 amd makes a loud beeps on starting up till the desktop appears .. any idea to solve this issue please ?
Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jun 21, 2015 | Dell Inspiron Computers & Internet
Tip
A Comprehensive Guide on Computer Beep Codes. (AWARD BIOS)
When a computer is booted up its BIOS, it performs a power-on self test, also known as POST, to test and verify the computers hardware and to make sure all components are working properly. Here's a comprehensive guide on how to determine which component has failed on a particular beep code and give you an idea on where to start for troubleshooting.
The exact meaning of the beep codes depends on the type and version of BIOS that you have. The three most popular types of BIOS are those made by Award, American Megatrends (AMI) and Phoenix. If you are using a PC made by a company that writes its own BIOS, e.g. DELL, HP, etc, you will have to consult your PC user's manual or the company's web site for assistance.
Beep Codes for Award Bios.
1 long, 2 short = Video adapter error
Troubleshooting: Either video adapter is bad or is not seated properly.
Repeating (endless loop) = Memory error
Troubleshooting: Check for improperly seated or missing memory. Reseat the memory if you can.
1 long, 3 short = No video card or bad video RAM.
Troubleshooting: Reseat or replace the video card.
High frequency beeps while running = Overheated CPU
Troubleshooting: Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low = CPU failure.Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Troubleshooting: Check the CPU fan or BIOS settings for proper fan speed.
I will be posting more tips on other versions of BIOS.
Hope this helps.
on Mar 25, 2011 | Computers & Internet
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
T6528, when trying to power up, no video, no beeps, cpu and case fan run at full speed. Tried removing memory, no beep at startup. PC was working fine before, and fans only came on when necessary. Some...
If there was a video error generally you would get beeps that are similar to removing the memory.
when this happens you are looking at a failed CPU or Motherboard. For the system to get to the POST it has to get past the CPU hence you have no beeps.
First thing would be to clear the bios and cmos. use the jumper and remove the battery.
If clearing does not work then you would remove the cpu, turn the system on, then off. then reseat the cpu and try it again (remember heatsink as well never turn a system on without the heatsink on it)
Jun 29, 2011 | E-Machines T6528 PC Desktop
When powered on unit only beeps. continuous beeping- approx 1 every two seconds. nothing boots up at all, only beeps! Tried removing memory thinking it may be a memory issue but that was not the issue!...
Hi
If you have a Gigabyte MoBo then the CPU fan has stopped running.
Open the casing side cover and see if the CPU cooling fan is running or not.
If it does not run, the go into BIOS and disable "HDD S.M.A.R.T. Capability" in Advanced Bios Features
also set "CPU smart fan control" to disable in PC Health Status
OR
This may be a power supply problem.
The voltages of the power supply are going out of limits.
change the power supply and see.
May 20, 2011 | HP Pavilion Media Center a1510n PC...
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
Video error beep codes not video problem
Sounds like Bad Memory chips try just using one chip. even though youve replaced the video card. so im guessing memory could be bad, at least one of them.
try not reseating them but just using one at a time in the slots
also yeah reseating the CPU can help too, an over heating CPU will still boot up, but not advisable. make sure heatsink is present and fans are working. thermal grease is good too on cpu.
but check memory if you have mixed memory like 128mb and 512mb chips try smaller one first if it works then try the higher one.
but sounds like a memory problem, they can go bad almost instantly.
GL
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 04, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Dec 15, 2007 | HP Compaq dc5100 PC Desktop
NFORCE3-A Won't post with 2 sticks of 512MB DDR RAM, only if 1 stick used :-(
U cannot use 2 identical DIMMs of RAM Memory, find two same and faster, couse 233 or 300 is too slow for nForce3 motherboard.
Aug 30, 2007 | EliteGroup nForce3-A Motherboard
Beep: 6 seconds on, 3 seconds off
Pull all the cards out. Put in the CPU and fan, just one memory chip, the video card and the hard drive. Plug in just the power supply and the powerbutton switch to motherboard. Don't connect anything but the monitor, mouse and keyboard. If you still get beeps, try another memory chip (just one). I don't know the beep codes for your motherboard so we have to do this one step at a time.
Jun 30, 2007 | FIC VC19 Motherboard
Matsonic MS9087C Motherboard Logo
50 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
