Question about Toshiba Qosmio G25-AV513 Notebook
Media and volume lights issue
TV Button and Media button blue lights always remain on as soon as I power it on. The Volume lights dont work after windows statrts but vloume does work. Volume lights work just before windows starts.
I have deleted and reinstalled both Qosmio player and windows but the problem is still there.
I know when i bought it nwe the lights would only come on when you pressed the TV or Media center buttons, and the volume would work with the blue lights going up and down.
Please help
    Genius:
  • 1,003 Answers
Use your recovery disk that came with your computer to reload all drivers and functions to this computer back up your hardrive first because this will will erase all non OEM programs, saved data and printers.
Posted on Jan 15, 2008
Headset will not re-set according to instructions. Indicator light is half red, half blue. What should I do?
I had the same issue with green light always on and not turning off. Call button plus volume up button did not work when the unit was not plugged in. When I plugged the unit in to charge, the volume up and call button (together) did reset the unit.
Oct 14, 2015 | AUVIO Bluetooth Headphones
Why does the volume on my Magnavox TV immmediately go to 0 as soon as I turn it on, and then after I turn it up and take my hand off the volume button?
it would appear Volume down button is either shorted or something is constantly pushing on it forcing the volume to go down. You could try to press on the down button and see if it feels like it pushes back a little bit. The most common thing is that it gets sticky from grimy, sticky fingers, try to un-stick it using some alcohol on a cotton swab. Other that the only way to fix this is to take the tv apart and figure out the button problem that way!
Good Luck!
Rich Lilja
Apr 02, 2015 | Funai Magnavox 32md301b/f7 32-inch 720p Tv...
Bt-100 bluetooth speaker volume to low can't turn up
There are several issues that may be causing the volume to be very low.
SPEAKER VOLUME:
(1) When you press the Vol+ button on the speaker does it make a beep sound? (It should, even if it can not longer go up or lower).
(2) Be sure to continue pressing the Vol+ Button to ensure that the volume does increase.
(3) While this is rarely an issue, may want to check that the speaker is charged.
DEVICE VOLUME:
*Please note that some devices have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Ensure that Media Volume is on.
(2) Ensure that the volume is turned up on the device by using the devices Vol+ controls
MEDIA VOLUME:
*Please also note that the media being used (Youtube, Hulu, Music Player, etc.) may ALSO have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Check that the volume within the media is turned up as well.
Hope this helps! You can also contact customer service for DIgix at 1-866-770-3688 for further assistance.
Jun 30, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Chunghop universal remote RM-306E code for lg tv
if you are using CHUNGHOP RM-306E this would be applicable for all brands of TV..
1) Turn on the TV
2) Press S button (top left corner) until red light on
3) Press Green button (power button top - right corner)
4) press volume + button (blue at the middle on the left) until the volume signal display on the TV
5) press S button again
Now you are set..
Test the remote function it should be working now.. if not repeat the steps above until you got it working..
Good luck..
May 07, 2014 | Televison & Video
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
Screen remains locked on Blue background welcome screen when it finally comes up. Status light remains blinking green. Over the past 7-10 days it took several tries powering on then off before picture...
Tv manual PCB control buttons all work?Like power on/off,volume - + and chanels + - all work than it not the manual PCB board control IR is parts of this board.Not the IR problems,when tv is finally on the remote work fully everything buttons?No,could be remote control have problems.Tv might have DM power supply board problems.
Feb 08, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
My JVC LT-42X579 42 in. LCD TV is only 13 MONTHS old and it suddenly won't turn on anymore. The blue power light comes on -as usual- but after 3 seconds, it will start blinking and it will remain that way...
I contact JVC and was told to first make sure your cable box or whatever you use to normally watch TV is powered on and is ready to work
He told me to unplug TV for 10 seconds at least. Then he had me press and hold down the "MENU and VOLUME DOWN (-)" buttons, at the same time for about 10 seconds. Then after 10 seconds of holding the 2 buttons down, he had me continue to hold the 2 buttons and press and let go of the power button. In other words after 10 seconds of holding down the volume down (-) and menu buttons, add the third button (power) and immediately let go of all 3 buttons, at the same time.
It worked for me instantlynd hopefully it works for you!!!
Nov 20, 2009 | JVC LT-42X579 42 in. LCD TV
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Volume Button.
hey there i have the same problem only difference is mine hasent fell off yet but mines broke while i was simply turning the volume up! and it happened the day i got it...i was not best pleased! lol
May 17, 2007 | Sony Network Walkman NW-A1200 MP3 Player
Volume issue on GO GEAR
Try to plug the headphones all the way in. If that dosen't work, it might be broken. Hope it works
Jan 10, 2007 | Philips GoGear HDD6330 MP3 Player
Toshiba Qosmio G25-AV513 Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
