Question about Panasonic KX-FL511 Plain Paper Laser Fax
Paper jams when trying to send fax (original goes in short way then jams) unit has had little use it establishes connection and then stops and jams when commencing scan
    Genius:
  • 1,003 Answers
Look in paper path(scanner compartment were paper feeds) to ensure there is no pieces of small paper or foriegn items in this area preventing paper from going all the way through if this fails clean the feed roller in document scan area with a micrfiber cloth moistened with rubbing alcohol
Posted on Jan 13, 2008
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Original jammed in fax feeder of Brother Intellifax 2800
    lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
    May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
    Fax in receiving faxes but not printing them.
    noavatar.png Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
    Apr 16, 2009 | Canon FAX-JX200
    Brother mfc 8220 gives error message check original but no paper jam exists.
    I assume you're getting this error when sending a fax?
    Check original is not a paper jam error. This can happen in the winter due to bad noise on the phone lines. When you send a fax, you can get this result from the receiving machine due to noise. The receiving unit will transmit the error back to the sending unit.
    The unit is basically asking you to check the quality of the original document. 90% of the time, there is no problem and the receiving unit actually got a good copy. However, sometimes due to noise on the line the receiving unit will get a poor copy of the fax. In this case the fax should be resent. Of course, since there is no way for you to determine how good the copy is at the receiving unit, in most instances you will have to resend the fax to make sure it goes though.
    If, however, you are getting this message while copying (very unlikely) you can do a simple test of the document scanner that should reassure you that there is no serious fault, or pinpoint the actual fault.
    Press the following key sequence within 2 seconds: MENU, *, 2, 8, 6, 4. If your unit has a FUNCTION key, use it in place of the MENU key. This should take you to maintenance mode. The display should say MAINTENANCE and all the lights should be flashing. If not, try unplugging the unit, press and hold either the MENU key or the FUNCTION key (depending on which your unit has) and plug the machine back in. This will also take you to maintenance mode.
    Now, just press 5 5. This is the scanner area setting command, and if there is any problem with your scanner it will show up here as an error. If there is no fault with the scanner, the unit should return to maintenance mode in a moment. Once done, press 9 9 to exit maintemance mode.
    If you are constantly having this error, get a phone repairman in to test your fax line.
    Feb 06, 2009 | Brother MFC-8220 Fax
    Paper jam sending faxes
    It is the document stop arm that is broken.You can remove it.The machine will work without it.
    Just make sure you remove the document stop arm and not one of the other sensor flags in the document feeder.
    Oct 27, 2008 | Canon FAXPHONE L80 Laser
    Paper jam
    sounds like you have a problem with the mechanicals, have it check by a certified tech. or junk it....hehehe!!!!
    Jul 24, 2008 | Panasonic KX-FP101 Plain Paper Thermal Fax
    HP 6210 using double paper?
    Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
    Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Fax document jam
    The document feeder rollers could be dirty. Try cleaning them with a lint-free cloth (not paper) and some alcohol. A commercial platen cleaner is best if you can buy some.
    Jan 08, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
    Panasonic KX-FL511 Plain Paper Laser Fax Logo
    247 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    jasbo
    jasbo
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
