Question about Nokia 2310 Cellular Phone
Nokia 2310 switching off
After inserting sim card mobile switching off
  • 2 more comments
  • gruwecrr Jan 14, 2008
    the nokia 2310 i have keeps turning it's self off even when i has full charge....any ideas
  • coraz Mar 03, 2008
    I have put a new sim card into my NOKIA 2310 (unlocked) and it keeps switching itself off before the NOKIA start up image is on the phone. the sim card works on another unlocked phone. And my old sim card doesn't cause the phone to switch itself off. Why would this happen with this particular sim card? How do I fix it?
  • Anonymous Sep 04, 2008
    nokia 2310 switching off problem
  • ruth-h Mar 11, 2009
    My nokia 2310 has been working fine, up until i switched it off. I now cant get it back on again, it switches on for 5 seconds then turns back off even when it is fully charged. This happened before when i got my new sim card, but sorted it self out after a few mins. At the moment, I have been trying to get my phone work for the last 15hours. Is there anything anyone can suggest? The phone is unlocked and I used to use a tmoblie sim card in it which worked fine, it is the O2 simcard I have the trouble with..
    Thanks
I have two of these phones. Both bought the same day recently. After just a few weeks, both started turning themselves off regularly. I eventually twigged that they were turning off as soon as I put them down onto a surface. Assuming a battery related problem, I crammed a piece of very thin cardboard into the back of each one between the battery and the rear cover of the phone. In each case the problem disappeared. Why is this so? Who knows!
Posted on Mar 05, 2008
  • 4 Answers
Reset the phone if it creating same prob. upgrade software
Posted on Jan 14, 2008
Insert sim solutions
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Nokia 2310 shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. Or make use of this Video to insert your Sim in your Nokia 2310. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Nokia 2310. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Mobileunlocksolutions.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Mar 04, 2013 | Nokia 2310 Cellular Phone
Nokia 2310 insert sim problem
If your mobile prompts "Insert SIM" even after putting the SIM in the mobile then there must be some problem with the mobile. The mobile is not able to read the SIM. Just put a paperweight above the SIM and close. Sure it should work otherwise get a solution from a service center.
May 28, 2012 | Nokia 2310 Cellular Phone
Nokia 2310 sim not valid
Do not worry unlocking can be done by many methods...........in that you can use the codes because its safe for your mobile..........
Get the unlocking instructions and code for your Nokia 2310 model mobile from this site Theunlockarena.com , here it can be done without any difficulty............
Mar 11, 2012 | Nokia 2310 Cellular Phone
When i am inserting my sim card in phone,the phone...
this can only be if the Sim card is not put correctly or the Sim card is short from inside or the Sim card slot of the phone is damaged!!try some other Sim card!
May 20, 2010 | Nokia 2310 Cellular Phone
Insert sim
Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using IPA solution. This problem is caused by Firmware problem and Hardware problem as well. Good luck.
May 15, 2010 | Nokia 1600 Cellular Phone
Unable to send messages from Nokia 2310
The problem could the SIM card or the phone. Remove the SIM card from the phone, insert it to another phone and try sending messages. If you can send messages then the problem lies in the phone. To verify, insert a different SIM card into your phone and try sending messages. The problem can be resolved by removing the battery and the SIM card from the phone then wait for at least 15 minutes before putting them back.
Apr 12, 2010 | Nokia 2310 Cellular Phone
Insert sim card showing
Try your sim card to another phone, or try another sim to that phone just to eliminte the problem. Sim card are easily ruin by static discharge
Jan 03, 2009 | Motorola Mobility RAZR V3
Nokia 2310 code error
if your mobile lock try 0000 or 1234, Or If U Change Default unlock Passward, Please go to Nokia Gallary In Your area and Ask them To Unlock Your Mobile.
If Your Sim card Lock their are two Solutions One is Call Cusomer care of vodaphone and ask them for PUK Code i.e. passward of Sim Card and another solution is if card rejected go to the nearest Vodaphone Gallary and askl them to unlock, it takes maximum 4 or 5 min.
May 19, 2008 | Nokia 2310 Cellular Phone
Nokia 2310 Cellular Phone Logo
283 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
