Question about Sony VAIO VGC-RB38G PC Desktop
Wii plug in
I see that my vgc-rb38g has a audio in and out jack as well as a video jack, however it doesn't seem like it is reading my wii when I plug it in. So how do I fix it?
    Sergeant:
  • 239 Answers
Plug the Wii into your computer and then try the add new hardware in you control panel, make sure you are plugged into the internet when you do, I think the drivers may need to be installed when the Wii is plugged in and on with you internet connection going in case it needs to update the drivers. I sure hope that gets you up and going, If not just write back here and I'll see what other solutions we can come up with. thanks
Posted on Jan 14, 2008
6ya staff
SOURCE:
Do all three plugs from the Wii have to be connected?
No. Only the video plug (the yellow one) and the left audio plug (the white one) need to be connected to the TV. You'll want to change the audio settings on the Wii to Mono; otherwise games may not sound right. This allows you to use the Wii on television sets that only have one audio input jack (mostly cheap ones).
Jan 09, 2014 | Nintendo Wii Console
I need 1440x900 drivers for a sony vaio vgc-rb38g
You can download the video and device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
Nov 28, 2012 | Sony VAIO VGC-RB38G PC Desktop
No sound
You have multiple playback devices go to: Start > Control Panel > Hardware and Sound > Manage Audio Device> Sound. Set speakers as default. Right click has Show Disabled and Disconnected devices.
Oct 14, 2012 | Sony VAIO VGC-RB38G PC Desktop
A friend of mine have a sony vaio vgc-rb38g desk top and she has a video card in her unit which was being used since purchase and it started giving her the message no input signal and the unit goes to...
Please check your video card for dirty conection ports and has it cleaned . Retry your PC. If problem persist, your video card is defective and need for replacement.
Regards
Sep 28, 2011 | Sony VAIO VGC-RB38G PC Desktop
I can't get video out to TV from Wii video input on receiver. Wii is connected to AV5. Video to TV is thru HDMI out on receiver to HDMI in on TV. I can port the audio but get no video
Hello there,
ok the setup you are using is a Receiver, TV, and Wii unit .
Step 1: plug one HDMI cable into the back of the Receiver unit on slot 2 name on it is called HDMI out jack
if looking at the back of the unit this slot is 2nd from the top left
Step 2: now plug the HDMI cable into the TV this is the cable you just plugged into the Receiver
TV done
Step 3: Wii Setup move the Yellow,White,Red cables over to the right if looking at the back of the unit 2 spots name for this group is called AV out Jacks .
Wii Done
now use the right input channel for this group and you should now See Wii playing .
Thank you and don't forget to Rate
Jan 26, 2011 | Yamaha RXV467 Receiver
I Have no motherboard diagram for my Sony Vaio VGC-RB38G
http://esupport.sony.com/perl/swu-list.pl?mdl=VGCRB38G
try that link, on left hand side of the page it says drivers and right under that is manuals specs and warranty. Should be able to find it in there someplace.
Jun 16, 2010 | Sony VAIO VGC-RB38G PC Desktop
My Sony VGC RB38G keeps losing power. I suspect it is an intermitent proble with the power supply. What is the part number for a replacement PSU and where can I get one?
You can call or go online to get the power supply you need. I recommend Tigerdirect.com, pricewatch.com, or 3btech.net.
Go online to get the phone #, and call to make sure you get the right one.
Nov 20, 2009 | Sony VAIO VGC-RB38G PC Desktop
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Apr 01, 2008 | Nintendo Wii Console
Sony VAIO VGC-RB38G PC Desktop Logo
374 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
