Question about HP 5510 4-in-one Printer
Copier leaves an ink line down the front of the document when fed through the unit.
There is no ink line when copy placed face down and scanned to copy.
  • karence Jan 13, 2008
    Thanks for your advice..... I can't seem to find the glass you are talking about. I've cleaned the glass under the lid where I put copies on the glass, but don't think that is the problem. Thanks again for trying and let me know if you have any more ideas.
  • 417 Answers
Hi there if the line appears when you use the document feeder then there is usually either Correction fluid or pen ink on the small piece of glass to the left of the main glass when you open the lid you can easily clean this by wiping the glass with windowlene or some sort of glass cleaner and this will get rid of your problem.
If the line appears when coping from the glass then the printout from the computer will be the same and that usually means that the print heads need cleaning. Take them out and using a soft cloth wipe the print heads clean from any dried toner.
Hope this help you
Thanks J
Posted on Jan 13, 2008
  • Jason Collin
    Jason Collin Jan 14, 2008
    If the glass is not to the left hand side open the document feeder as you would to remove a jam and there should be a thin glass receiver there clean this.
    If not let me know and I'll check the manual
    Thanks J
Yep, only when you use the document feeder? If so, lift the document feeder lid, get a clean lint-free cloth and some glass cleaner. Apply some of the cleaner to the cloth then, clean the small of the two glass areas. That is the only section that reads documents fed through the document feeder! Run a blank sheet of paper through the document feeder first before cleaning and make a copy. Take the copy and, if there is a line (or lines)on the copy, place it on the larger document glass face up.Follow the line to the smaller glass. The dot of debris will usually be there. If you don't see anything wrong, clean the glass anyway. Run another blank sheet through the document feeder. Check that copy. If the lines are gone...Viola! you have solved the problem. It it has not and you've cleaned it more than once, the debris is on the mirrors under the glass and a technician will need to come out, remove the glass and carefully clean the optics/mirrors.
Good Luck.
Aug 28, 2017 | HP Office Equipment & Supplies
When we feed documents through the document feeder the copies come out blurred. We do not have that problem when we place the documents directly on the glass plate.
When paper is fed through the document feeder it scans the whole page on a little strip of glass about an inch wide and about 12 inches long. That strip has dirt on it that needs cleaned off. Lay the bad copy on the glass (face up) and you can line it up with that little glass and see where the lines match up. Clean that little glass with alcohol or glass cleaner and it will be fixed :)
Mar 31, 2015 | Office Equipment & Supplies
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
Nov 21, 2010 | Office Equipment & Supplies
On a scanned document there is a line down the right hand side as if there is a mark on the paper. This is not the case and is only showing on the scanned document. How do I rectify this?
This line is being caused by something stuck to your scanner glass. It simply needs to be cleaned. The scanner glass is going to be located in 1 of 2 places. Most common is location is just to the left side of the large scanner glass. So lift up your document feeder and look at the large glass where you may sometimes place an original to be scanned or copied. Now look just to the left of that glass. Do you see a much thinner "strip" of glass? If so then clean this strip glass with a soft cloth and a bit of glass cleaner or water. If there is no strip glass located here then it will be located inside of the feeder area where you documents are fed in to be scanned. These feeder units usually just pop open. If your documents go in face up the the strip glass will be on the upper portion. More common is the face down feeding which means the glass will be on the bottom. Sometimes a flashlight is handy here. Just open up the feeder unit and look for a thin strip of glass that runs from the front towards the back. It is about 1 inch wide. Once you locate it just clean it as mentioned above. Close everything back up and give it a try.
Eccentially what is happening here is that something has gotten stuck to the glass and since when scanning, the documents are "dragged" past this glass, anything that is stuck or stationary on the glass is read as a solid line.
Nov 09, 2010 | OKI Electric Industry C3520 Laser Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
When the Automatic Document Feeder (ADF) to copy I
There are two scan modes when copies are made.When you make copies through ADF you originals go past small **** glass located to the left of the main exposure glass.Any small mark on this **** glass( correction fluid mark,ink mark,small scratch,dust particle and so on)will show as a line on your copy.So to get rid of these vertical lines on your copies you need to clean this small exposure glass.
Oct 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP 5510 4-in-one Printer Logo
124 people viewed this question
Ben Johnson
