Question about RCA RS2640 CD Shelf System
No sound No audio I have no sound And The tape player will not turn on. The two NTE7186 audio output transister have been replaced. What...
  • tmaxxnitro Mar 11, 2008
    i also have this problem tha tape si not working and there is no sound i think there is a voltage missing can you hel on this one.
    model rs 2640 rca.
    Patrick.
  • mlinacre Jan 04, 2009
    how do you change fuses
Check the fuses
Posted on Jan 24, 2008
    Problem Solver:
  • 5 Answers
Check tranistor 2sc3203y (q401)/replace with nte 382/it fixed my problem
Posted on Aug 24, 2008
How to repair Track 1 on 8 Track Tape Player?
It sounds like you have a bad tape or the 8 track head has to be adjusted.
Mar 19, 2018 | Panasonic Audio Players & Recorders
Akai Reel-to-Reel Tape Recorder Model X2000SD how do I hook up the cables for sound? I can get sound through the speakers, but can't turn it up.
Most reel to reel tape recorders have "line out" in the form of RCA phono jacks. These are designed to be connected to an external amplifier. Some unit, however also have an internal amplifier and will output to speaker jacks that should be clearly marked. If your unit has such jacks and you cannot control the sound, your amplifier must be bad. Keep in mind, on most recorders, there are no internal speakers or output amplifier and the volume controls on the front are for recording only.
Apr 29, 2017 | Akai Audio Players & Recorders
Right side no sound to speakers
The output transisters for that side are probally blowin,
Dec 06, 2012 | Technics SA-EX110 Receiver
I purchased an old Realistic TRC-431 CB. When I turned it on it worked fine, the mic was keyed then the lights went dim and stayed dim. Now the lights remain dim. I checked the two output transistors...
The problem is with your power supply. There should be a big round transister on the power supply this is the power transister. It will be mounted to the power supply case. Replace this transister and try to operaste your radio again. Make sure that the power supply you use is at leat 7 amps or the radio will not operate properly and you will possibly blow the transister again.
Jul 16, 2011 | Radio Communications
Can not get sound playing a vcr tape but can get sound playing a dvd please help
What connections are you using for the DVD and VCR output for both the video and audio?
If you are using a "digital" signal (such as optical audio/HDMI/etc) the VCR audio will not pass through these outputs. You will need to connect up the analog (red/white) RCA connectors on the back of your unit to hear the VCR audio
I hope this help, Magoo
Mar 06, 2011 | Toshiba DVR670 Player
What is an output transistor?
output tranisister is the transister that give the finial output of sound.
some use a output IC for the same purpose.
Aug 31, 2008 | Sherwood R-945 Receiver
How to connect eq to audio amp
To EQ all audio sources you'll need to have a receiver/amp with either a tape monitor loop or a pre amp-in/main-out loop. Look for a button on the front labelled 'Tape Mon' or ins and outs on the back labelled pre amp-out/main-in. If you have these you can connect the outs from the amp to the ins on your EQ and then EQ outs go back into the amps ins. If you have a tape deck as well, the EQ's 'tape mon' jacks replace the ones it takes up on the amp, so just plug your tape deck in here.
Just remember that whether you have a tape deck or not, if you hang an EQ off the 'tape mon' loop you'll have to engage the 'tape mon' button/switch for playback with EQ.
If your amp doesn't have these loops you can still use EQ but you may be restriced to one audio component source. So say you wanted to EQ the playback from your CD player, you'd just connect the CD players output into the EQs input, then connect the EQ's output into the amplifiers input (for CD player). Then everything you play through the CD player will be EQ'd.
Jan 01, 2008 | Audio Players & Recorders
RCA RS2640 CD Shelf System Logo
342 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
